• Latest threads
    • Custom feed
      • Updates
        Old 16th September 2006, 21:52   #1 (permalink)
        London Mike
        London Mike's Avatar
        So where's the fuse???
        OK, while messing around doing the wiring in the main electrics box in the engine compartment, the one with the DME in, the main red power feed on the little post managed to get touched to earth and blew the fuse. The question is where IS the fuse, we can't find it anywhere...
        If you look at the battery there are 3 main power leads coming off the + terminal. One is the main one, another smaller one goes across behind the battery and runs up the side of the tunnel, this one has a black box with a big fused link which is intact, it isn't that one. It's the one that runs down with the main power lead just inside the right hand sill. We can't see a fuse either at the battery end or in the front footwell where it emerges before going up into the electrics box
        Anyone had a look with the carpets out and know where the fuse is? We have no power to the post in the electrics box anymore and we've run out of places to look. I'm loathe to rip out all the carpet to trace the whole length, I can't see why they'd fuse it there as it could be so easily done next to the battery...
        M5·0 VEE
        London Mike is offline
        Old 18th September 2006, 01:16   #2 (permalink)
        London Mike
        NOBODY knows???
        M5·0 VEE
        Old 18th September 2006, 09:52   #3 (permalink)
        AliveM5
        Was there much of a "bang" when you shorted out the post to earth ? maybe the wire itself has melted somewhere along its length.
        AliveM5 is offline
        Old 18th September 2006, 11:03   #4 (permalink)
        London Mike
        Nope, it was a quick contact with no real 'bang' and the wire is about 10mm thick so it hasn't melted for sure
        M5·0 VEE
        Old 18th September 2006, 11:25   #5 (permalink)
        yewcorner
        yewcorner's Avatar
        Mike,
        I've had the carpet up before as I was looking at why one of speakers was 'whining'. I don't remember seeing any fuses?
        Originally Posted by London Mike
        NOBODY knows???
        1992 3.8, Avus Blue
        yewcorner is offline
        Old 18th September 2006, 11:54   #6 (permalink)
        tadpole
        Have you checked under the near side rear seat. There are some fuses, some of which are under a cover you have to unscrew. I have not got the car otherwise I would have a check for you.
        Phil..
        tadpole is offline
        Old 18th September 2006, 12:01   #7 (permalink)
        London Mike
        Phil..
        It's not in there, that are all the fuses for central locking and similar, the power lines are on the right hand side
        M5·0 VEE
        Old 18th September 2006, 14:33   #8 (permalink)
        madm5
        madm5's Avatar
        Do you mean the + connector under the bonnet for jump starting? If so i think the red wire goes straight to the alternator with no fuse.
        VW polo
        M5 3.8 SOLD
        madm5 is offline
        Old 18th September 2006, 15:13   #9 (permalink)
        unesential
        Send a message via AIM to unesential
        There is no fuse listed. Wire should run direct to Under bonnet terminal post. From there back to the battery. Terminal in DME box for bus to DME, Airpump, and Fuel Pump relay. Back to B+ terminal then to battery. Fused wire from battery goes to power distribution.
        unesential is offline
        Old 18th September 2006, 15:16   #10 (permalink)
        The Bigfella
        The Bigfella's Avatar
        This is sounding like you have a session with a multimeter and some jumper leads coming up. You have my sympathies - I just rewired the genset engine on my boat.
        Ian
        The Bigfella is offline
        Old 18th September 2006, 16:49   #11 (permalink)
        London Mike
        And this is what is worrying me, that's how I understood it too. But we have no power at the terminal so something's wrong. Yup, a long session with a meter looks like the way forward here. Oh goody...
        M5·0 VEE
        Old 18th September 2006, 19:57   #12 (permalink)
        unesential
        Check for power at the B+ post. If you are good there then it is cable to DME bus. If not my sympathies.
        Old 21st September 2006, 10:46   #13 (permalink)
        London Mike
        It has an in-line fused link that is underneath the rubber sheathing. You have to pull the cable through from the battery compartment into the rear footwell then peel back the rubber to get to it. I cut it our and replaced it with a proper large 50 fuse which is now mounted next to the battery
        M5·0 VEE
