Old 23rd August 2006, 22:45   #1
nixter
nixter's Avatar
Garage: '93 E34 M5 (Silver)
slight glovebox sag
My glovebox hangs a little bit lower on the right side when in the closed position, (LHD). Is there someway to correct this?
cheers,
n
1993 M5 Silver/Black
1980 911SC Widebody, Black/Black
nixter is offline
Old 23rd August 2006, 23:15   #2
VentoGT
VentoGT's Avatar
Garage: 2002 e46 M3 Carbon Black
Mine does as well--in fact, just about every picture of these cars, LHD or RHD, have sagging offside glove boxes. Mine has an annoying squeak when going over bumps as well...I'll watch this thread to see any ideas popping up.
1991 e34 M5 Sterlingsilber/Light Silvergrey
1962 356 T-6B Coupe Champagne/Black
1988 M491 911 3.2 Cab Granite Green/Linen
VentoGT is offline
Old 23rd August 2006, 23:20   #3
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
Easily adjustable, but a pain to get perfect...
If you read early road tests of the E34 they always complain about
the fit of the glove box !
If you look down under the dash ( you'll need to stick your head in
the footwell..) you'll find two plastic lock tabs at either end of the lower
glovebox hinges...these can be unlocked by hand and allow quite a large
amount of adjustment so you can play around with the lid to dash alighnment.
Have fun, oh and its virtually impossible to get perfectly square !
Alan.
///M5 the only substitute for capacity is even greater capacity...
Alan Archer is offline
Old 23rd August 2006, 23:52   #4
nixter
nixter's Avatar
Sounds like a challenge to me!
n
nixter is offline
Old 24th August 2006, 00:51   #5
Jahangeer
Jahangeer's Avatar
Garage: .................
My glove box problem is that the door really needs a good old shove to close it, but it fits very well, I have had it out a few times though.
Regards
J
Jahangeer is offline
Old 24th August 2006, 01:05   #6
Sebring NL
Sebring NL's Avatar
Mine had the habit of opening up under spirited driving, mainly because it;s always loaded too heavy..Just lock it and the problem is gone..Jus' never to unlock it again whilst driving unless you have a spare key in there..You would not be the first.
Sebring NL is offline
Old 24th August 2006, 03:36   #7
Stevie
Stevie's Avatar
Garage: e34 540i, Orientblau
The only way to solve it is to shorten the cloth strap so it is the same lenght as the little damping strut. BTW if you take out the glovebox you see the bar it's hinged on is crooked as well so it'll always be a b*tch to get straight........
Stevie is offline
Old 24th August 2006, 04:02   #8
geecee
geecee's Avatar
Garage: 1990 E34 M5 / Alpine White
Don't get me started on adjusting the effing glovebox.
If you can get it to line up, then it will rattle. If you can stop the rattle, you need to be Samson to shut it.
The guy who designed it probably did the wipers and the fan too.
best of luck, mate.
geecee is offline
Old 24th August 2006, 04:08   #9
Stevie
Stevie's Avatar
Now that you mention it, the are indeed engineering parralells in those components........ Probably tested and approved by some Essex engineer!
best of luck, mate.
Stevie is offline
Old 24th August 2006, 05:16   #10
nixter
nixter's Avatar
Funny, I was going through my receipts the other day to look for recent valve adjusts (there were none) but I did notice that during one of the cars very first services that the service rep had written down "customer complained of crooked glovebox, please adjust"
hehe.
n
nixter is offline
Slight initial hickup under WOT nixter E34 M5 Discussion 5 31st May 2006 23:30
B10 Bi-Turbo: Slight rear shudder in 1st gear & other puppypilgrim ALPINABoard.com | BMW Alpina Discussion 7 24th May 2006 02:15
Question: Slight vibration hum inside steering column? ATLANTA M5 E39 M5 and E52 Z8 Discussion 0 29th October 2005 00:55
Should I get the glovebox flashlight? Ashok Arora E39 M5 and E52 Z8 Discussion 21 1st August 2002 04:26
slight vibration when braking at speed steve adams E39 M5 and E52 Z8 Discussion 12 5th January 2002 04:02
Page generated in 0.15314 seconds with 11 queries
