Old 11th August 2006, 22:42   #1
M5Sime
M5Sime's Avatar
Garage: M5 Imola Red
Send a message via Yahoo to M5Sime
Variable Intake Manifold
Fellow M5ers,
I have started thinking about the variable intake and whether it is working. There is a bellows mechanism fed from some kind of pump just under the intake manifold (to improve the torque by varying the length of the inlet tract).
I have done some scientific sucking on the pipe and this moves the valve, but I do not think it is operating. Without a vacuum gauge etc.. How easy are these to diagnose/replace the pump/valve that is under the intake chamber??
Everything else seems to be ok, and revs hard and cleanly.. Just thinking there might be more!
Appreciate your comments
Simon
LE 22/50
M5Sime..
From E39 M5 to E34 M5
M5Sime is offline
Old 12th August 2006, 21:23   #2
fugginfazt
Garage: DINAN e34 m5 alpine white
Send a message via MSN to fugginfazt
Check for valve actuation when turning key on
fugginfazt is offline
Old 12th August 2006, 21:50   #3
Sebring NL
Sebring NL's Avatar
LE=3.8= without self-test as the valve operates via DME unlike 3.6
Sebring NL is offline
Old 12th August 2006, 22:17   #4
M5Piojo
M5Piojo's Avatar
Garage: MY 95 Avus Blau
You can still test it by revving your engine (when oil temp is ok offcourse). Just pull the throttle linkage in the engine bay by hand (to full extend) and the valve should then open and close.
Bjorn
-10/1989 Sebring Grau (R.I.P.)
-07/1991 Macao Blau (Sold)
-03/1992 Brilliantrot (Sold)
-09/2002 Carbonblack (Sold)
-12/1994 Avus Blau Touring
M5Piojo is offline
Old 13th August 2006, 21:34   #5
M5Sime
M5Sime's Avatar
Problem me thinks!
Hi,
I did some digging around, looking at www.realoem.com for the parts and diagrams and following some pipes.
I think the tube (vacuum) should run to the end of the head, under the black plastic sensor bit on the end of the cams and then down by the waterways and exhaust part of the engine.. I assume to take a feed from the emission pump?
This pipe has melted and was just hanging there.. My valve never moves with revving or startup and so I have perhaps other things not working as well!
I have attached a pic of the pipework. Anyone have any ideas where valve item 12 is in this pic??
Cheers
Simon
M5Sime..
M5Sime is offline
Old 13th August 2006, 22:18   #6
yewcorner
yewcorner's Avatar
Garage: E60 M5 Interlagos Blue
This may help you in replacing all your vacuum hoses.
QUOTE=M5Sime]Hi,
Cheers
Simon[/quote]
2005 E60 M5 Interlagos blue
yewcorner is offline
Old 13th August 2006, 22:53   #7
M5Sime
M5Sime's Avatar
Simon
[/quote]
Thanks!! This is indeed useful. I have had the plenum off when I did the starter motor. According to your diagram the hose that I have traced to suspected nowhere town is 'Vacuum hose to air injection shutoff'
I think I need the plenum out again and checking all my hoses and their operation. I never get a self test and a guessing there is no vacuum in the system at all.
M5Sime..
M5Sime is offline
Old 14th August 2006, 00:05   #8
yewcorner
yewcorner's Avatar
What we do to check the actuator is to put a blob of grease on the back of the screw, then, after you have warmed your baby up, is to give it full throttle a couple of times. Stop the car and check that there is grease on both sides of contact. Works every time.
I think I need the plenum out again and checking all my hoses and their operation. I never get a self test and a guessing there is no vacuum in the system at all.[/quote]
Old 14th August 2006, 10:36   #9
M5Sime
M5Sime's Avatar
No connection
Hi Yewcorner,
Thanks for this idea. I was thinking of ways to test this. What I need to look at now is what is the pipe that ends in a melted nothing towards the emission pump.. and what is this valve that I assume is fed from the emission pump (in the pic I posted).
Item 12 ..
Any ideas? I shall hunt around and perhaps ask the Stratstone BMW guys as they have the car for an Insp1 this week.. (great price as well).
Cheers
Simon
M5Sime..
M5Sime is offline
Old 14th August 2006, 14:14   #10
Simonal
Simonal's Avatar
Garage: Alpina B10 V8s Touring
Originally Posted by M5Sime
Hi Yewcorner,
Item 12 ..
Cheers
Simon
Hi Simon (great name by the way... )
I had an issue with the this a while back at idle the car does not move the resonance flap as it appears it is controlled by the electronic brain and this will know that the car is not in motion and thus does not need this to operate.
But after using the "blob o' grease" test it was proved that it was working so I was a happy person. That was the next thing to check but Yewcorner beat me to it.
Hope this also helps.
Simon
Simonal is offline
TECH: Replacing intake Camshaft Position Sensor... BlueBomber E39 M5 and E52 Z8 Discussion 70 15th May 2009 08:42
Intake Manifold upgrade pamato E39 M5 and E52 Z8 Discussion 15 7th March 2006 17:45
Interesting article on plastic intake manifold kees E60 M5 and E61 M5 Touring Discussion 2 1st February 2006 18:37
Another HD intake and brake duct ArrestMeRed E39 M5 and E52 Z8 Discussion 9 5th September 2004 16:37
8 Brandnew Candle holders for the S62! Take a look! TriflowM5+M3 E39 M5 and E52 Z8 Discussion 56 26th October 2003 20:41
Page generated in 0.16707 seconds with 12 queries
