Old 9th August 2006, 21:05   #1
hertfordshire1
hertfordshire1's Avatar
Garage: BMW M5 e34
Whats wrong with this pic
Ok, just so you get an idea, I drove the car today maybe 20 miles.
The oil on the cardboard is where its dripped while parked, the oil on the drive was after being parked 2 hours when i got back..
So whats leaking??
Steve
Also, what causes the transmission or diff to whine, and why would a clutch slip thats already been replaced twice in 2 years??
"If it breaks again.................. I give up."
hertfordshire1 is offline
Old 9th August 2006, 21:11   #2
Geach
Geach's Avatar
Garage: 1990 e34 M5 Sebring grey
So whats leaking??
Steve
Rear main oil seal? Looks more like engine oil than gearbox oil?
Dan.
'90 M5- Sebring Grey
Geach is offline
Old 9th August 2006, 21:21   #3
illjah
Garage: 1995 M5 LE40/50 Orinico Green
Looks like engine oil on the cardboard to me.
Diff whines when on full lock at slow speed means its on the way out.
Your diff (is that it in pics 2 & 3 or is that your gearbox? Can't tell...) leak does not look significant, and certainly not enough to cause the spillage on the card.
Was that under the rear of the car then??
Clutch can get knackered with (ab)use. We all know you don't pussy foot around in the ///M so.... when did you last replace it? Perhaps you need to improve your heel&toe technique???
illjah is offline
Old 9th August 2006, 21:24   #4
hertfordshire1
Garage: BMW M5 e34
Rear main oil seal was replaced at the same time as the clutch was done, 05/05 roughly 20k miles ago.
If it has gone again, BMW parts come with a 2 year warranty?
Steve
Old 9th August 2006, 21:25   #5
hertfordshire1
Garage: BMW M5 e34
Hi mate, pics 2 and 3 are of the back of the engine/gearbox.
I get a constant whining regardless of lock etc....
Old 9th August 2006, 21:28   #6
Geach
Geach's Avatar
Steve
Did BMW do the work? Its worth a try,dont know if they will be too keen to put it right for you for free though?
Dan.
Geach is offline
Old 9th August 2006, 21:30   #7
hertfordshire1
Garage: BMW M5 e34
All work was done at PMW, i took my car to a BMW main dealer once, never again...
Old 9th August 2006, 21:32   #8
illjah
ok.
if oil has got into the clutch, that could cause it to slip.
Diff whine is normally pretty bad news, can you see if its leakking at all? My LE has a reasonable leak from the diff (its not getting used til its fixed) but is still silent. Def get the level checked and topped up if necessary, but it may be too late....
illjah is offline
Old 9th August 2006, 21:35   #9
Geach
Geach's Avatar
Looks like you are gonna have to check all the levels and see where the oil has actually come from? And then go from there. Sorry not to be an awful lot of help!
Dan.
Geach is offline
Old 9th August 2006, 21:35   #10
hertfordshire1
Garage: BMW M5 e34
ok.
Al, back of the car is dry, no visible signs of any leaks at all.
The whine changes pitch with the engine noise, so as i accelerate (gradual) it gets higher pitched.....
Steve
Hamann M6 pic Zlaatan GTBoard.com: General Sportscars 6 19th March 2006 01:07
Is this really so wrong?? MartinW E60 M5 and E61 M5 Touring Discussion 12 16th January 2005 00:44
Lets chat "what goes wrong with CPS" vics E39 M5 and E52 Z8 Discussion 3 2nd December 2004 18:44
PIC Is This How You "Cord" Your Tires?/ Ck Out The Stuck On Brake Dust Anita E39 M5 and E52 Z8 Discussion 15 14th September 2004 08:00
the pic that started it all- thanks boston rocket! Paul S E39 M5 and E52 Z8 Discussion 14 10th February 2003 00:05
Page generated in 0.15065 seconds with 12 queries
