Old 9th August 2006, 18:09   #1
GoneAgain
GoneAgain's Avatar
Garage: 1988 Sebring Grey.....waking up
Rear Pitman Arms. Easy job??
Evening all,
Just failed my Controle Technique(MOT) on rear pitman arms (No 6).
How easy are they to change? can i do it in my dingy undergroud carpark fairly easily?
Looks like unbolt old ones & bolt on the new ones.
Any tips?
Cheers lads.
Look on the bright side, if I don't drive it for a year (2 years) the engine rebuild will pay for itself.(I'll make a profit!!).
GoneAgain is offline
Old 9th August 2006, 20:51   #2
Geach
Geach's Avatar
Garage: 1990 e34 M5 Sebring grey
Originally Posted by GoneAgain
Evening all,
Any tips?
Cheers lads.
Yes thats about it! un bolt and bolt on new,no probs at all! Good luck
(the bolts can be bloody tight sometimes)
Dan.
'90 M5- Sebring Grey
Geach is offline
Old 10th August 2006, 14:50   #3
SezaGeoff
SezaGeoff's Avatar
Garage: 1990 E34 M5 Calypsorot/Black
It needs to be done when the wheels are in normal position, so don't jack it up. You need to do it on a hoist that raises the car by the wheels, not on a two- or four-post hoist. I hope you are skinny
Otherwise, it is just undo and bolt up the new ones.
SezaGeoff, Melbourne Australia
WBSHD92 (90 3.6), WBADC22 (87 535i Exec), WB10422 (98 1100s), WBACB12 (95 320i Manual) WBADT62 (02 530i MSport)
SezaGeoff is offline
Old 10th August 2006, 15:11   #4
GoneAgain
GoneAgain's Avatar
Cheers lads.
SG, that was my next question. Thanks, guess I'll have to find a handy kerb, when it stops raining!
T
Old 10th August 2006, 15:36   #5
cchase009
Garage: E34 M5 Black
Or yo can jak the whole car, change the parts, lower and torque with a long torque bar.
I did it this way earlier this year and I am not skinny.
You will find the right side a little trickier than the left so be prepared.
C. Chase
cchase009 is offline
Old 10th August 2006, 16:03   #6
yewcorner
yewcorner's Avatar
Garage: E60 M5 Interlagos Blue
Also, you need to lock the top nut (which I didn't do which added a further 10 minutes to the job) with a spanner/socket.
C. Chase
2005 E60 M5 Interlagos blue
yewcorner is offline
rattle/knock noise from rear solved! Jacob Lee E39 M5 and E52 Z8 Discussion 4 14th April 2009 21:08
Shark Injector for E46 M3 pride355 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 14 11th June 2003 08:47
QUESTION: regarding rear diff. for the M5 compared to the Z8 rear diff......... FAST 5 E39 M5 and E52 Z8 Discussion 2 25th March 2003 14:07
M5 rear deck removal for stereo upgrade (pics!) sysvr4 E39 M5 and E52 Z8 Discussion 1 9th July 2002 00:54
Heated rear seats \ rear door sun blinds john elmes E34 M5 Discussion 6 6th May 2001 20:50
Page generated in 0.13520 seconds with 12 queries
