Old 5th August 2006, 17:42   #1
Ole O
Garage: E34 M5 3.8, DiamantSchwartzMetallic
Send a message via MSN to Ole O
Troubleshooting gearbox problem?
Hi.. Drove today, and the gearbox suddenly stucked in 2gear. Canīt get it out of 2 gear.. The gear stick feels like the car not are in gear ?
Looked under the car after if the gear stick was loose, but itīs not loose and is connected to the gearbox
Then i need to replace the gearbox right ? Itīs an 3.8 gearbox, but i know someone who has a 3.6gearbox. I know there not should be any difference. Can i "just" set the 3.6 gearbox on ?? Or is there a difference with the clutch or something else ?
Ole O is offline
Old 6th August 2006, 01:10   #2
madm5
madm5's Avatar
Garage: BMW M5 3.8 white SOLD
I'd be tempted to see exactly why the box stuck in second- is it out of oil or something? They normally show signs of wear going in to gear in the first place as a sign of needing replacement. Regardless-- it is a straight swap to put a 3.6 box in a 3.8, this is what I have had done.
VW polo
M5 3.8 SOLD
madm5 is offline
Old 6th August 2006, 14:14   #3
Ole O
U mean that i should check if itīs "just" need oil ?
There have not been any problem with ot before and no bad noises..
What about the clutch ? does that fit on the 3.6 gearbox ?
Ole O is offline
Old 6th August 2006, 14:19   #4
DrSakke
DrSakke's Avatar
Hi!
Propably not just an oil-problem....
Take the box down and see what the problem is...
And yes, there is no problems fitting the 3.6 box. NO problems with the clutch.
SAkke
"You canīt afford cheap things if youīre poor"
DrSakke is offline
Old 6th August 2006, 14:21   #5
Ole O
Originally Posted by DrSakke
Hi!
SAkke
Thanks for the quick answers
Hehe i canīt take it off myself.. Havenīt done that on any cars before, but knows people who can. One of my buddies knows a Gearbox mechanic, so i try to make him look at it..
Ole O is offline
Old 14th August 2006, 18:21   #6
Ole O
We have just taking the gearbox off today, because the gearbox mechanic didnīt have time...
There are 2 things i would like to know what is on the gearbox:
Ole O is offline
Old 14th August 2006, 19:01   #7
Sebring NL
Sebring NL's Avatar
2nd pic is reverse light switch.
First is ventilation pipe
Sebring NL is offline
Old 14th August 2006, 21:20   #8
StevieBoy
StevieBoy's Avatar
Garage: E39 Silverstone M5
The first picture shows that you should visit your tyre dealer !!!!!
It looks like you've been doing
steve
StevieBoy is offline
Troubleshooting lack of power to audio system? jarodclark Bavarian Soundwerks' Car Audio & Electronics Forum 5 21st August 2006 16:33
Troubleshooting lack of power to audio system? jarodclark E39 M5 and E52 Z8 Discussion 4 1st August 2006 01:32
M6 gearbox problem after 2 months mat10874 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 11 25th September 2005 03:28
Power steering gearbox failed jay wilkins E34 M5 Discussion 0 29th July 2001 13:13
Page generated in 0.13737 seconds with 11 queries
