Old 3rd August 2006, 21:03   #1
dchyde
Garage: 1993 Alpina B10 Bi-Turbo
Range And MPG Readings High
I have noticed that my MPG reading is about twice what it should be. It says I am getting 28 miles per gallon. Also, when my tank is full the range reads like 900 miles left. As we all know this is not possible on two tanks of gas. Everything else seems to be working OK; speedo, fuel gauge, etc. I wonder if this has something to do with the euro conversion or is there a different fuel tank sensor for the computer that is malfunctioning.
1993 Alpina B10 Bi-Turbo #362
1995 ///M5 3.8 (sold)
1991 ///M5 3.6 (sold)
dchyde is offline
Old 3rd August 2006, 21:17   #2
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Mine's the opposite.
I can drive upto 100 miles on the red. OBC says I never have enough fuel.
You have to accept that these cars are old now and things don't work aswell as they should. Or these particular instruments don't work very well from the offset.
My freinds Alpina B10 V8 always suggests it's doing 10mpg and always has more fuel than indicated.
Same thing on most E30's.
Maybe it's a BMW thing!
Sal
Avus Blue 6 speed 3.8L E34 ///M5 Sedan
Evolve ECU Remap / Chip | Evolve Carbon Intake | Powerflex Black | Whiteline | Eibach Springs
2001 E39 530iA Sport
Cyrus is offline
Old 3rd August 2006, 21:20   #3
dchyde
I guess I am always hopeful for an easy fix. I should know better now.
dchyde is offline
Old 4th August 2006, 00:16   #4
VentoGT
VentoGT's Avatar
Garage: 2002 e46 M3 Carbon Black
Speaking of--how many gallons are the US M5 tanks? I seem to only be able to put in 15.5-16 Gallons when my car is in the red, and I read that some of the e34 cars have 21 gallon tanks...my sender may be off...
1991 e34 M5 Sterlingsilber/Light Silvergrey
1962 356 T-6B Coupe Champagne/Black
1988 M491 911 3.2 Cab Granite Green/Linen
VentoGT is offline
Old 5th August 2006, 02:33   #5
GDA
GDA's Avatar
Garage: 1995 M5 Cosmosschwarz
Derek
Fill up your tank completely and then do OBC test number #7. This tells you how many litres you have remaining in your tank. If it registers 80, then in Federalization the OBC got reset with US data. A really good dealer can reprogram the OBC with your Euro coding. Once its back to 90 litres you can refine the actual using the correction factor in test #20.
Look here for the details...
http://bmwe34m5.com/node/231
Oh, probably cost you at least 1/2 hour of master tech time unless you have a VERY friendly dealer....
Greg
GDA
1995 M5
GDA is offline
Old 5th August 2006, 03:06   #6
dchyde
Greg,
Thanks for the info. I will give it a try, it won't take long to burn through the rest of my tank.
Cheers,
Derek
dchyde is offline
Old 8th August 2006, 19:11   #7
dchyde
Greg,
Filled the tank and ran the test, the obc showed just under 80 litres. You were right on thanks. So I guess I have to get it programmed now. I assume like most of this devices, it has to be flashed with special equipment, there is not a switch or something.
Derek
dchyde is offline
Old 8th August 2006, 19:22   #8
illjah
Garage: 1995 M5 LE40/50 Orinico Green
Didn't some cars only have an 81 litre tank though? Although I believe this is not common...
illjah is offline
Old 8th August 2006, 20:06   #9
derhammer
derhammer's Avatar
Garage: M5 3,6 sterling silber
I have the same problem!
derhammer is offline
Old 8th August 2006, 21:10   #10
DCN M5
DCN M5's Avatar
Garage: 1991 E34 M5
US gallons
The most I have ever put in is 70.7 liters which is about 18.7 US gallongs. Mine is a North American 91 3.6 version.
DCN
91 M5
88 911
DCN M5 is offline
Mileage and Range dave E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 12 9th January 2006 15:51
Geneva jon.c E60 M5 and E61 M5 Touring Discussion 2 25th February 2005 22:40
Quick question regarding M5 mpg calculations DIPLOMAT E39 M5 and E52 Z8 Discussion 26 30th December 2004 17:51
Page generated in 0.14265 seconds with 11 queries
