Old 3rd August 2006, 19:32   #1
IvanDias
IvanDias's Avatar
Full tank but fuel gauge reading only 3/4. Resetting?
Hi,
After a few months, ok, a year or more, of driving about adding £10/£20/£30 of fuel at a time, I have noticed both times I have recently filled it right up, that the fuel gauge only snaps up to 3/4, not to full.
It certainly did it before.
Does anyone know a way of recalibrating it?
I considered running it completely out and then filling from a can, then tanking up from a petrol station, but a recent post warning that the fuel pump is fuel cooled has put me off. That bit of info certainly seemed logical given that my tank reads empty yet only takes 65 or so litres to fill.
While I'm here, I'd like to point out that the yellow low fuel light has never illuminated on my car, no matter how low the fuel, even after I kicked the engine with under a litre in the tank ages ago.
Regards
Ivan
IvanDias is offline
Old 3rd August 2006, 19:42   #2
illjah
Garage: 1995 M5 LE40/50 Orinico Green
I found my fuel guage to slowly get more accurate if i filled up every time rather than £10/£20 at a time - as you say be carefull of running too low, as i used to run it really low every time before refil, and we'll i had a fuel pump failure (still worked but undersupplying pressure, but to inspect it looked like it was working) and that caused me all sorts of problems when it ran lean, blew MAF etc etc.
But there might be a more technical way of getting it to read correctly. Have you checked that the needle isn't loose in the display or something silly like that!!
illjah is offline
Old 3rd August 2006, 19:51   #3
GoneAgain
GoneAgain's Avatar
Garage: 1988 Sebring Grey.....waking up
I find that mine sometimes sticks the other way. It will read 40litres in the tank when it's definitely running lower, but only occasionally, but the warning light will still come on at 20 litres.
I tend to use he OBC reading for fuel in the tank ,test 06 or 07 - I find it very accurate.
I think you can set the warning light threshold through the OBC, but not certain & certainly don't know how to do it.
Can't help with your specific problem though!
T
Look on the bright side, if I don't drive it for a year (2 years) the engine rebuild will pay for itself.(I'll make a profit!!).
GoneAgain is offline
How to test the MAFs yourself and How MAFs work DavidS E39 M5 and E52 Z8 Discussion 386 19th March 2010 16:16
Fuel Gauge not what it seems MAH E39 M5 and E52 Z8 Discussion 38 14th December 2006 01:13
Has anyone ever experimented with additives....... FAST 5 Off Topic Forum 15 20th September 2005 03:48
Air / Fuel reading with Dinan CAI & High Flow Airmass Meters? howler E39 M5 and E52 Z8 Discussion 4 18th September 2004 04:03
How much fuel is full? vadas1 E34 M5 Discussion 8 25th November 2002 21:42
Page generated in 0.10774 seconds with 11 queries
