Old 3rd August 2006, 15:22   #1
Jon Baker
Jon Baker's Avatar
Garage: E34 M5 3.8 - Daytona Violet
Windscreen Washers
My main windscreen washers have stopped working.
The intense screenwash function still works but the main washers do not pull anything through.
Any ideas as to what could be causing this malfunction?
Fingers crossed this is not going to end up costing a fortune to put right.
Jon Baker is offline
Old 3rd August 2006, 15:56   #2
yewcorner
yewcorner's Avatar
Garage: E60 M5 Interlagos Blue
Either pump has failed or there is a break in the wiring. You should try changing the pump electrical leads to prove one way or the other.
2005 E60 M5 Interlagos blue
yewcorner is offline
Old 3rd August 2006, 16:02   #3
Sebring NL
Sebring NL's Avatar
Jon
When I got my car, wiring was a mess in the washer-tank department. I reckon I got it sorted, but it appears to be broken again or still.
The wires were extremely brittle in my car and the general socket setup is very fragile IMO.
Try looking into that first before detaching the actual jets in the bonnet as its easy to damage the paint when disassembling, you want to take those out as least as possible, i.e. when you are sure nothing else causes the problem.
W
Sebring NL is offline
Old 3rd August 2006, 16:32   #4
yewcorner
yewcorner's Avatar
Hey Wout
Are the sockets/wiring located beneath the water bottles? I need to do mine and also connect a new foglamp/outside temp harness, but couldn't see anything which might help.
thanks
Originally Posted by Sebring NL
Jon
W
Old 3rd August 2006, 16:41   #5
Wane Ramsay
Wane Ramsay's Avatar
Garage: Estoril blue E39 M5 Individual 2001
Sounds to me that your jets are blocked. Try poking a needle in the holes as you operate the intensive cleaner. If this works then you need to clean-out the complete system by flushing it through with clean water.
Wane Ramsay is offline
Old 3rd August 2006, 17:52   #6
Chas C
Chas C's Avatar
Garage: Alpinas
If the intense function works then the jets are fine. It's most likely just a tube has disconnected between the the main reservior and the jets.
If the motor works, but nothing comes through the jets, look for a dribble of water appearing under the bonnet or around the headlamp washers. This should indicate the source of any disconnection.
If the motor isn't working, the problem is electrical - check fuses, motor and wiring.
Chas
E32 Alpina B3.5 (Alpina Green/Beige)
E34 Alpina B10 BiTurbo #290 (Diamondblack/black)
E36 Alpina B8 4.6 Coupe #015 (Alpina Blue/Blue)
E39 Alpina B10 V8 #003/1 (Scarab/Pearl Beige)
Honda CBR1100XX
Chas C is offline
Old 4th August 2006, 02:49   #7
nebpor
Garage: Avus Blue E34 3.8 M5
Hi mate, I had this exact same problem a month ago.
All wiring was checked and we found it fine.
So we took the motor out of the intensive wash bottle and swapped it with the main wash bottle .... no intensive wash, but now the main one works at least, until I find a replacement
nebpor is offline
Old 4th August 2006, 02:55   #8
M540i LE
M540i LE's Avatar
Garage: 1995 M540i Limited Edition (Arctic Silver) & 1985 Hartge H23 (Alpine White)
I don't have intensive wash, so I'm not sure, but it sounds from the posts below that the windscreen and intensive have separate motors.
The motor on my windscreen washers went on my old 540iLE with same effect. Replaced it for about A$25 from the dealer - so not an expensive part and about 5 minutes to swap it over.
David B
Register of the 524 RHD 3.6 E34 M5's made - http://autos.groups.yahoo.com/group/E34M5RHD-register/
Register of the 70 540iLE's made - http://autos.groups.yahoo.com/group/BMW540iLE/
M540i LE is offline
Old 4th August 2006, 10:18   #9
Jon Baker
Jon Baker's Avatar
Thanks for all of you replies.
I had a bit of a poke around under the bonnet last night. All wiring looks intact so am thinking it may be the motor. I will try taking the intensive motor out and swapping it for the main one.
Nice to here that a part may need replacing that doesn't cost a fortune.
Jon
Old 4th August 2006, 11:09   #10
DaveW
Garage: Alpina B10 Bi-Turbo in Macau Blue
Slightly off-topic but my intensive wash has a mind of it's own and will run at will (nothing to do with the 5 cycle wash of the main washers).
Anyone know where the intensive wash controller/relay sits?
Dave.
DaveW is offline
Thoughts on automatic headlights and headlight washers? Clem E39 M5 and E52 Z8 Discussion 20 2nd August 2006 10:55
Wiper broke windscreen Simon E34 M5 Discussion 9 17th December 2002 02:46
(UK) - MOT test with regard to stonechip on windscreen advice ? IvanDias E34 M5 Discussion 4 4th April 2002 01:29
Cracked windscreen mikek E34 M5 Discussion 7 19th March 2002 02:04
Adjusting headlight washers Roger Rabbit E34 M5 Discussion 3 22nd January 2002 19:21
Page generated in 0.16622 seconds with 11 queries
