All,
I just thought I'd give you an update on the Eibach springs I had fitted to
my car nearly 2 weeks ago. The ride is much better, fine bumps have the edge
taken off them whereas the stock springs used to transmit every little bump.
The only problem with the eibachs is that they are too soft, much softer
than the original springs, and given that they are also shorter, the result
is that I can easily hit the bump stops over large bumps, or even when
cornering hard.
So, after driving across a railway line today, and having the front spring
bottom out again, I've decided that I'm giung to swap them over for
something else. The obvious choice is the progressive H&R's, any other
options?
John
