what is the AUC sensor? - BMW M5 Forum and M6 Forums
post #1 of 9 Old 7th July 2006, 10:22 AM Thread Starter
Ruppy
Ruppy's Avatar
Hi guys.
On the air filter box, a AUC sensor. What is? What for?
Frank
///M5 3.8 1993, 345/328 big brake...gone but never forgotten
E30 327i turbo...gone but never forgotten
Ruppy is offline
post #2 of 9 Old 7th July 2006, 11:06 AM
Billie_S38
Billie_S38's Avatar
Originally Posted by Ruppy
Hi guys.
Frank
Frank,
The AUC sensor under the airfilterbox is for the climate control to keep polution outside the car. It is only working when you have the circulation button on the climate control panel.
Serge
Billie_S38 is offline
post #3 of 9 Old 7th July 2006, 11:18 AM Thread Starter
Ruppy
Ruppy's Avatar
I have a standard clima.
3 button.
One for te compressor start, one for the circulation and the third is for windscreen heater.
whitout this AUC sensore the circulation is not working?
Ruppy is offline
post #4 of 9 Old 7th July 2006, 02:12 PM
Billie_S38
Billie_S38's Avatar
3 button.
When you have the button with the 2 circles and the A.
http://http://www.m5board.com/vbulle...1&d=1152273732
post #5 of 9 Old 7th July 2006, 05:03 PM Thread Starter
Ruppy
Ruppy's Avatar
So my standard clima not use it.
Thx.
Ruppy is offline
post #6 of 9 Old 7th July 2006, 06:44 PM
Chewbacca
Chewbacca's Avatar
Hmmm, if you have the AUC sensor, you should have AUC and thus the correct button. Cars without AUC got a normal "circulation" button with just that function. AUC cars got a "circulation" button with two LEDs: the first push triggers AUC and the second (2nd LED lit) activates circulation.
Kind regards,
Tobias
Chewbacca is offline
post #7 of 9 Old 7th July 2006, 06:50 PM
Stevie
Stevie's Avatar
Don't mind me clearing this up: The three circular arrows on the button mean REcirculation, meaning the car will not allow outside air to come in. In cars without AUC (like mine) that means the driver closes it by pushing the button, wether it automaticaly disengeages I haven's found out. I think it should.....
AUC when active (LED on) will close the car for outside air when it detects smog or pollution, to open again when it thinks the air is clean enough OR the passenger compartement has had the same air for too long.
Stevie is offline
post #8 of 9 Old 8th July 2006, 09:39 AM
Billie_S38
Billie_S38's Avatar
The button ahs 3 functions :
LED's out :
normal function, fresh air
Left LED on:
automatic system when high polution is measured fresh air valve
close and only the air in the car circulates, when polution is
low valves open again.
Right LED on:
Fresh air valves are closed and only air in the car circulates.
It is not recommended to use this option for longer times
because it does'n't use fresh air anymore.
post #9 of 9 Old 10th July 2006, 03:56 PM
Chewbacca
Chewbacca's Avatar
No problem. Thats what I wanted to say, the boundaries of my knowledge of the English language kept me from sayin it that way.
Kind regards,
Tobias
post #10 of 9 Old 7th March 2015, 08:02 PM
Mojeferlop
Mojeferlop is offline
TECH: Replacing intake Camshaft Position Sensor... BlueBomber E39 M5 and E52 Z8 Discussion 94 29th September 2012 05:14 PM
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 09:23 AM
Alert: oil sensor failure drbmw E60 M5 and E61 M5 Touring Discussion 16 5th January 2006 12:11 AM
Rain Sensor Operation? hal2000 E60 M5 and E61 M5 Touring Discussion 4 26th December 2005 04:37 PM
Can broken cam sensor make lambda sensor before kat to show wrong values?? blitzkrieg E39 M5 and E52 Z8 Discussion 0 15th June 2005 02:04 PM
