Suspension w/o SLS - BMW M5 Forum and M6 Forums
Old 2nd June 2006, 19:16   #1
ilovemy_e34
Garage: 1991 M5 Brillant Red
Suspension w/o SLS
Okay I just finished reading an exhaustive amout of Threads regarding suspension. I am still left with one question.
I have a 1991 3.6 M5 with stock sway bars but the SLS (self leveling system?) seems to have been deleted??? In the rear I just see some hydrolic lines zip-tied back... I am assuming the front is the same way.
and I am to assume that mine never came with EDC (Electronic Dynamic Control??)
So with that in mind should I go with the 535i suspension setup???
H&R front lowering (535i) 1.3 inches
H&R rear lowering (535i) .75 inches
or should I still install the the M5 set
which is 1.25 in the front and .3 in the rear.
(I plan to use Bilstein Sport shocks and stock sway bars and tirewear is not really a big, big deal for me, though I will take it into mind)
Does anyone else have an M5 like mine. It makes me sad... like a dog with three legs. lol
Thanks guys,
-Cory
Even the wisest of doctors are relying on scientific truths, the errors of which will be recognized within a few years time. – Marcel Proust
ilovemy_e34 is offline   Reply With Quote
Old 2nd June 2006, 19:58   #2
noMi5
noMi5's Avatar
Garage: E34 M5 No Longer Owned now E24 635csi Diamond Black
Thanks guys,
Hi there,
Just deleted the SLS on mine (1990 3.6 M5) after one of the rear struts started leaking intermittently.
As far as I believe the 3.6 never came with EDC - only SLS on the rear.
I opted for the 535i springs, 29672-1, coupled,at the moment,with standard shocks on the front and Koni 8240-1076 on the rear.
No problems so far whatsoever - obviously sits a bit lower at the front now (tyres fill the arches nicely) but very little difference at the rear, and the ride is pretty close to standard - depending on how soft/hard you set the Konis.
Simon.
noMi5 is offline   Reply With Quote
Old 3rd June 2006, 01:13   #3
Sebring NL
Sebring NL's Avatar
Garage: many, www.wheelmen.wordpress.com
Hi
3.6 never had EDC
Change PAS pump to 535 one when deleting SLS. Topping off hoses will work temporarily only as my SLS hose blew @ 220 km/h. Recircing will cause the press difference between the whole SLS trace and the 50cm return hose to become evident through a pulsing noise, as many members can vouch for after riding shotgun in my car at the Nürburgring.
Sebring NL is offline   Reply With Quote
Old 4th June 2006, 09:47   #4
noMi5
noMi5's Avatar
Originally Posted by Sebring NL
Hi
Hi,
Heres a question.
Once the SLS has been deleted, and the PAS pump is therefore only serving the steering, does the system still require Pentosin or was that specific oil only required for the SLS struts.
I`m assuming that if you were to change to the 535 one you would be using standard PAS oil ie ATF.
Simon.
Old 5th June 2006, 20:29   #5
cchase009
Garage: E34 M5 Black
All,
changing the power steering pump is not required as long as the supply and return lines are connected together (recirculated) with the female-female ended brake hose from the 1600. I deleted my SLS and I no such noise.
C. Chase
'91 M5
cchase009 is offline   Reply With Quote
Old 5th June 2006, 21:52   #6
illjah
Garage: 1995 M5 LE40/50 Orinico Green
mines topped off, but welded, no probs so far, but there is a lot of un-necessary pipework & accumulators that I'd like to get rid of, as SebringNL states (and as I feared when first doing this) they are a possible source of leaks.
I've got H&R and Koni adjustables all round, i really like it.
illjah is offline   Reply With Quote
Old 6th June 2006, 03:14   #7
cchase009
When you use the hose to recirculate the supply and return lines, both accumalatros and the piping in the rear can be removed.
Check www.bavauto.com under the suspension section for an M5. They sell a kit which you DO NOT need to buy, just the brake hose from the 1600. The pdf diagram they provide on the site shows the parts that can be removed.
C. Chase
'91 M5
Old 6th June 2006, 08:32   #8
noMi5
noMi5's Avatar
C. Chase
'91 M5
Thats the site I referred to when doing mine.
Instead of buying either the kit or a brake hose I went to the local motor factors who supply brake pipe and fittings and purchased the threaded connection you use at the ends of the rigid pipework (there were 2 different sizes so I purchased a couple of each - a matter of pence) and welded the hole closed - hence a solid plug which I used to plug the system at the regulator (as per the pdf diagram on the site).http://www.bavauto.com/Assets/inst_p...34ElimKits.pdf
This allowed me to then remove everything back from the regulator.
Old 3rd January 2011, 01:55   #9
Rorschach
Garage: E34 Black
Originally Posted by noMi5 View Post
Heres a question.
Once the SLS has been deleted, and the PAS pump is therefore only serving the steering, does the system still require Pentosin ?...
Also interested .. So, is the steering pump also designed to run specifically on the CHF (7.1/11s) ? Or after the sls delete , one can use regular ATF ?
Thankyou.
Rorschach is offline   Reply With Quote
Old 4th January 2011, 00:05   #10
Sebring NL
Sebring NL's Avatar
Always use prescribed PEntosin , even if you mix them up (dealers have the tendancy to say that 11 is an improved version of 7, which is SO wrong) you will get leaks.
ONLY use the Pentosin as described on the lid.
E30 M3, E30 325i, Alpina C1 2.5,Alpina B6 3.5, Alpina B6 3.5s, E38 L7 , E30 550i S62 , and many more
Visit our site for pictures and info:
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows,Alpina V12 E31
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily-SOLD
Suspension upgrade / SLS delete illjah E34 M5 Discussion 5 7th November 2005 20:36
More Suspension woes (SLS) Brian M5 E34 M5 Discussion 3 11th April 2005 13:39
Question about the corvette and suspension in general? paulh GTBoard.com: General Sportscars 1 10th March 2005 17:51
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 21:03
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav Most Memorable Threads' 0 4th July 2004 21:03
