Guys
Problem with EDC after recently changing the battery. Switch on ignition (stage 2), EDC switch on dash lights up but goes out after about 5 seconds. Then a bong...message displays 'EDC not active - check owners handbook'. Took out back seat to check EDC Control unit (see attached) and fuse...all seems OK. Then noticed a disconnected wire (probably happened when I disconnected negative lead from battery) from a plug leading to or from the EDC Control Unit (see attached).
Could this be the problem??
Your advice and comments are greatly appreciated.
PS Apologies for blurry photos
_____________
Beast = M5 3.8l
