Fitted the EDC Switch!! - BMW M5 Forum and M6 Forums
Old 16th May 2006, 14:48   #1
Jahangeer
Jahangeer's Avatar
Garage: .................
Well finally I got the edc switch fitted to the correct wiring behind the light switch - thanks guys!
Just a question - why does my EDC switch not have a green light on the "S" setting?
Regards
J
Jahangeer is offline   Reply With Quote
Old 16th May 2006, 15:19   #2
Simonal
Simonal's Avatar
Garage: Alpina B10 V8S Touring
Congratulations J
Could it be the bulb blown....doh!
Should light in both positions.
Simonal is offline   Reply With Quote
Old 16th May 2006, 15:36   #3
Jahangeer
Jahangeer's Avatar
Originally Posted by Simonal
Congratulations J
yep great eh!!
it should light....mmm ok, will swap with a mates with his edc switch, just to test it.
Old 16th May 2006, 16:17   #4
Phlem5
Garage: 92 3.8, 5sp, Avus Blue(SOLD) & 95 LE 25/50
Well done ,that man. Persistance pays off ! as they say.
Phil.
Phlem5 is offline   Reply With Quote
Old 16th May 2006, 17:54   #5
Simonal
Simonal's Avatar
yep great eh!!
Hope that works otherwise you may need a new switch. Still at least you will have a place to put it.
Old 16th May 2006, 18:45   #6
M5Micke
M5Micke's Avatar
Garage: M5 3,8l Daytonaviolett
Great Jahangeer.
So it were the switch behind the dash? Now I´m going to get one for my self and put it in the car.
Very nice
//Micke
With Alutech Raceparts exhaust, 345mm floating disc, M-Tech mirror (OEM) and 18" BBS LM
M5Micke is offline   Reply With Quote
Old 16th May 2006, 20:37   #7
farrell
farrell's Avatar
Sales Feedback: (4)
Farrell
farrell is offline   Reply With Quote
Old 16th May 2006, 21:40   #8
hertfordshire1
hertfordshire1's Avatar
Garage: BMW M5 e34
I'm confused...
I thought all edc cars had the switch?
Can someone explain?
Steve
"If it breaks again.................. I give up."
hertfordshire1 is offline   Reply With Quote
Old 16th May 2006, 21:49   #9
Stevie
Stevie's Avatar
Garage: e34 540iT/6, Granitsilber
Originally Posted by hertfordshire1
I'm confused...
Steve
Oh come on! All 3,8 had EDC, only N'ring-pack cars had wide rear wheels, thicker rear ARB and the manual-override-switch for the EDC.......
Stevie is offline   Reply With Quote
Old 16th May 2006, 22:21   #10
hertfordshire1
Garage: BMW M5 e34
so by retro fitting the switch, does not make it the same set up as the ring spec'd cars because of the ARB and wheels?
Steve
EDC Control switch Fash E34 M5 Discussion 18 12th July 2011 15:33
EDC Switch......again!! Jahangeer E34 M5 Discussion 8 15th July 2005 10:11
Help on EDC Switch installation on LHD 3,8 Jahangeer E34 M5 Discussion 4 10th June 2005 17:11
EDC III Switch Question enjoymentman E34 M5 Discussion 11 3rd February 2005 20:52
Correct illumination of EDC switch Tubbs E34 M5 Discussion 22 25th September 2004 23:46
