Old 12th May 2006, 11:18   #1
UltFamCar
UltFamCar's Avatar
Garage: 1991 Dinan E34 M5
Send a message via AIM to UltFamCar Send a message via Yahoo to UltFamCar
Thoughts on my M5 after being in the shop, and question about oil leak...
Thought I share with everyone after getting my 91 M5 (125k miles) back
from my local regular indie shop with labor rate of $110/hour:
1. Inspection I: I brought most of my own parts (from BMA) except
washer fluid, valve cover gaskets, valve shims and differential seal
ring). Labor = $400
2. Brake flush and replace master cylinder rubber grommets. Labor for
brake flush = $100
3. Coolant flush. Labor = $88
4. Replace drive shaft flex disc. Labor = $44
5. Install StopTech SS brakelines F/R. Labor = $165
6. Replace F/R brake pads (Hawk HPS/Axxis Ultimates respectively) and
F/R rotors (Centric), all brake parts from zeckhausen.com. Labor = $330
7. Replace fuel hoses from tank to filter and from filter to fuel
line. P/L = $81
8. Replace all 3 drive belts. P/L = $165
9. Replaced differential fluid (Royal Purple Synchromax). Labor = $30
...and finally...
10. Install UUC SSK/DSSR, black tranny mounts (and new shift knob.
Labor = $220 (although advisor said it took a lot longer than 2 hours
to install)
Gotta say the M5 felt like new again, and absolutely LOVE the UUC SSK.
Made sure to give them all applicable written instructions (e.g.
don't over-torque the tranny mounts). So how did I do? Do the labor
rates look reasonable for a SF bay area indie shop?
Here's a quote they gave me for fixing the front end oil leak. Please
give me your thoughts on price:
Problems found: Engine oil pan bolts loose and one missing. Replace
lower oil pan gasket, valve cover gasket, and front timing cover
gaskets. P/L estimate = $2392
How many of you live with the slight leak and pressure wash the
undercarriage when needed?
Thanks,
Charles
E34 1991 Dinan M5 | Jet Black/Black | '93 Clutch & Flywheel | Dinan Chip | Dinan Stage I BBK (F/R Centric Rotors, Front Hawk HPS Pads, Rear Axxis Ultimate Pads)| F/R StopTech SS Brake Lines | Dinan Stage III Suspension | Dinan Floor Mats | OEM F/R Clears | UUC EVO3 SSK & DSSR | UUC Black Transmission Mounts | BMWCCA #275170
E39 1999 528i Touring | Touring Sport Package | Auto | Jet Black | Black Montana Leather | Xenons | Moon | Heated Seats | OEM Alarm | OEM M5 Front Bumper Kit | OEM M5 Rear Sway Bar | Brembo OE Replacement Rotors | StopTech SS Brake Lines | Axxis Ultimate Brake Pads | ATE TYP 200 Brake Fluid | (Wifey's Car)
E46 - 1999 323i | Sport | Manual | Jet Black | Tan | Myrtle Wood | Moon | Rear-folding seats | Michelin Pilot Sports | OEM Clears | UUC BB Clutch Stop | M3 Lip Spoiler | Dinan Stage I [SOLD]
Words of Wisdom:
"Friends don't let friends drive automatics!"
"If it ain't RWD, it's WWD (Wrong Wheel Drive)!"
UltFamCar is offline
Old 13th May 2006, 01:58   #2
bobz
bobz's Avatar
Garage: E34 M5 Black
I would live with the slight oil leak.
If you decide to do the work then at least replace the oil pump and chain giudes.
BobZ
bobz is offline
Old 13th May 2006, 03:17   #3
Phlem5
Garage: 92 3.8, 5sp, Avus Blue(SOLD) & 95 LE 25/50
Charles, can't comment on the labour rate's but, are you sure the guy put RP Synchromax in your differential ?. As I understand it synchromax should be used in the gearbox in place of automatic transmission fluid. The Diff / Final drive unit should be filled with Castrol saf xj 75/140 or other high quality oil of similar spec, specifically for LSD diffs.
Phil.
Phlem5 is offline
Old 17th September 2006, 18:00   #4
Binary Star
Binary Star's Avatar
Garage: Maurituis Bleu Metallic
Thanks,
Charles
sounds reasonable, what's the name of the shop?
Binary Star is offline
Old 17th September 2006, 21:09   #5
Jahangeer
Jahangeer's Avatar
Garage: .................
I had my lower oil pan gasket replaed, it only cost around 2500sek, so 400usd ish.
Regards
J
Jahangeer is offline
Old 19th September 2006, 21:44   #6
StevieBoy
StevieBoy's Avatar
Garage: E39 Silverstone M5
Thanks,
Charles
[/quote]
The "front timing cover gasket" ... do you mean the crankshaft oil seal?
If you do... it costs about 10 USD and takes about an hour or two to fix
Over 2000 dollars for the three !!!! EEEEEK!!!
I have lived with the oil leaks for 1 year and after replacing sump gasket crankshaft seal and diff seal ....thy're gone !! Horrray !!
Total cost about 300 usd (200 quid in real money )
Oh !! and 20 quid for power washing every now and then
steve
StevieBoy is offline
Old 19th September 2006, 23:59   #7
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
Labor rates seem normal. The work buy the book for replacing those gaskets is a bit much. If you are going to open it up then I would change oil pump and the associated timing chain parts as when these need to be done yuo will repeating the work.
unesential is offline
Old 20th September 2006, 00:43   #8
fugginfazt
Garage: DINAN e34 m5 alpine white
Send a message via MSN to fugginfazt
Had same job done here in San Luis Obispo for 850.00 parts and labor
fugginfazt is offline
Oil Analysis of Royal Purple Racing 51 vs LUCAS Synthetic vs Castrol 10w60 vs Mobil 1 KingM5 E39 M5 and E52 Z8 Discussion 41 28th April 2006 22:38
'02 M5 in the shop - CV joint Driveshaft fasteddie E39 M5 and E52 Z8 Discussion 10 17th June 2005 05:13
Another M3 CSL Question re wheels for M5 Rcl4668 E39 M5 and E52 Z8 Discussion 1 11th May 2003 18:09
QUESTION: Regarding M5 disc brake rotors................ FAST 5 E39 M5 and E52 Z8 Discussion 5 26th March 2003 00:51
ot: Just raced with a DINAN M5! JIMMY E39 M5 and E52 Z8 Discussion 15 26th April 2002 04:12
Page generated in 0.14270 seconds with 11 queries
