Old 11th April 2006, 21:01   #1
nixter
nixter's Avatar
Garage: '93 E34 M5 (Silver)
changing brake pads/rotors
Hey guys, I notice the M5 FAQ page seems to be having issues again and I'm about to change my rotors and pads. I was hoping to find a walk through. I haven't done this before but I'm mechanically inclined so I'm confident I can do this given the proper knowledge.
Can anyone point me to a walkthough or help me out? I love learning how to DIY with this car!
Nix
1993 M5 Silver/Black
1980 911SC Widebody, Black/Black
nixter is offline
Old 11th April 2006, 22:24   #2
yewcorner
yewcorner's Avatar
Garage: E60 M5 Interlagos Blue
This website is possibly better: http://www.bmwe34.net/e34main/mainte...kes/rotors.htm
Bit on pads is here: http://www.bmwe34.net/e34main/mainte...rakes/pads.htm
2005 E60 M5 Interlagos blue
yewcorner is offline
Old 12th April 2006, 00:30   #3
DookSD
DookSD's Avatar
Garage: e34 M5 Silver
it's pretty straightforward once you get the wheels off.
Basically:
Remove Wheel (17mjm socket)
Remove Caliper pins (7mm Hex)
Remove Caliper and support it (I just rested it on the lower control arms)
Remove Pads (and wear sensors where applicable) (Front Left and Rear Right on my car)
Remove Caliper Carrier (19mm Socket Front and 15mm Rear) Fronts required a breaker bar to remove about 100lbs/ft of torque.
Remove Rotor set screw (5mm hex)
Remove Rotor
Installation is reverse of removal.
1991 E34 M5 Silver
DookSD is offline
Old 12th April 2006, 00:34   #4
nixter
nixter's Avatar
Thanks guys! Yewcorner, that's the page I was talking about, it was down earlier though.
Cheers,
nix
nixter is offline
Changing Brake Pads vabchbmw E39 M5 and E52 Z8 Discussion 15 20th November 2005 22:00
Changing Brake Hose Questions WylM5 E34 M5 Discussion 1 23rd September 2004 22:26
Need Brake / ABS expert advice DavidS E39 M5 and E52 Z8 Discussion 1 6th August 2004 19:25
Changing to EBC Red Brake Pads. Any gotchas on the install? gmiles E39 M5 and E52 Z8 Discussion 1 22nd March 2004 16:40
Changing Brake pads-why not BMW? Mel A E34 M5 Discussion 6 25th July 2000 19:35
Page generated in 0.10436 seconds with 11 queries
