Old 10th April 2006, 11:35   #1
Chas C
Chas C's Avatar
Garage: Alpinas
A question of lubrication
I'd like to change the engine, gearbox and diff oils.
What's percieved wisdom with regard to the best brand of oils to use in the 3.6 (@100k miles)? There's an engine bay sticker which tells me to use Wintershall oil !
Am I right in thinking the manual box uses auto transmission fluid?
What about the diff?
Any advice gratefully received.
Chas
E32 Alpina B3.5 (Alpina Green/Beige)
E34 Alpina B10 BiTurbo #290 (Diamondblack/black)
E36 Alpina B8 4.6 Coupe #015 (Alpina Blue/Blue)
E39 Alpina B10 V8 #003/1 (Scarab/Pearl Beige)
Honda CBR1100XX
Chas C is offline
Old 10th April 2006, 12:41   #2
noMi5
noMi5's Avatar
Garage: E34 3.6 M5 Diamond Black/Extended Champagne Leather
Hi Chas,
I`m about to do the exact same.
Have searched around the forum with regards to this subject and as usual there are varying preferences.
Diff - Castrol SAF-XJ 75W-140 API GL5 seems to be the real mccoy
Castrol Syntrax 75W-90 appears to be an acceptable alternative
Gearbox - Depends on what derivative of box you have.
There are 4 different coloured labels on the casings informing
you which oil to use - mine is Orange and states ATF.
I`m about to use Dexron III based on info found on this forum.
Engine - Real varying thoughts/advice on this one - Mineral? Synthetic?
I use 10W40 Castrol non-synthetic again based on advice found
here.
The choice is yours.
Hope that starts pointing you in some sort of direction.
Cheers.
noMi5 is offline
Old 10th April 2006, 12:54   #3
illjah
Garage: 1995 M5 LE40/50 Orinico Green
I've just changed my gearbox oil to redline atf, its supposed to make for a smoother/quieter change. I'm yet to drive it tho! Previously just had normal atf....
i bought two bottles from here:
http://www.mtmotorsport.co.uk/redline/
also added an STP gearbox additive (which I think consists of molybdenum disulphide) to try and quieten my 6 speed at idle.
don't even get into the subject of engine oils - like tyre choice its a very personal choice, but most 10W/40 semi-synthetic is ok. a search will pull up plenty of long winded threads about fully synthetics, and the use of the higher 'quality' oils etc.
illjah is offline
Old 10th April 2006, 20:34   #4
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
I change the gearbox & diff oil every year,
this time round I used Dextron III in the box and its an improvement
on shift quality compaired to earlier oils used.
Castrol oil in the diff too (off the shelf so easy peasy).
Alan.
///M5 the only substitute for capacity is even greater capacity...
Alan Archer is offline
Old 10th April 2006, 20:40   #5
ilovemy_e34
Garage: 1991 M5 Brillant Red
"A question of lubrication"
In America you would be making reference to which intimate lubricant to choose...
Lubrication in America translates to OIL, I mean OIL -- say it from the gut; as if all economic, political and ethical decisions revolve around this dark muck.
Just FYI
-Cory
Even the wisest of doctors are relying on scientific truths, the errors of which will be recognized within a few years time. – Marcel Proust
ilovemy_e34 is offline
Old 10th April 2006, 21:08   #6
Sebring NL
Sebring NL's Avatar
Wintershall..That's a nice story..It used to be a factory made by the Nazi's in WWII for experimental fuel etc. BMW appears to have bought this factory and used its formula's for the mixture that was used in the Turbo F-1 cars and the M3 touringcars.
I'm having the oil in the box and diff changed before the 'Ring meeting, and have got me some Castrol oil from a supplier to try for the 'box . I'll look up the exact specs as I have the bottles at the office.
Sebring NL is offline
Old 10th April 2006, 21:12   #7
graham4242
graham4242's Avatar
Garage: e60 B5s
For engine OIL I use 0-40 RS seams OK very smoth idle (relativly). Go on Chas be a bit different - but if your car blows up don't blame me OK!
Are you going to Scone at the end of the month? with this total BMW malarky?
graham4242 is offline
Old 10th April 2006, 21:13   #8
yewcorner
yewcorner's Avatar
Garage: E60 M5 Interlagos Blue
I'm using Amsoil ATF for gearbox and their LSD diff oil 75/95. Currently Silkolene 15w50 synthetic for the engine.
2005 E60 M5 Interlagos blue
yewcorner is offline
Old 10th April 2006, 21:41   #9
Chas C
Chas C's Avatar
Garage: Alpinas
I'm planning to. I've also PM'd the details to another two owners on this board from God's country so we could have at least 4 E34s there
Chas
Honda CBR1100XX
Chas C is offline
Old 10th April 2006, 21:45   #10
Chas C
Chas C's Avatar
Garage: Alpinas
And that's why I chose it - you can't beat of double entendre to get a response to a thread
Chas
Honda CBR1100XX
Chas C is offline
To Bluetooth or Not to Bluetooth, Alas the Question yapallas E39 M5 and E52 Z8 Discussion 50 30th July 2005 03:34
Silly question: Which color do you use on your NAV? ngc5904 E39 M5 and E52 Z8 Discussion 10 30th June 2004 09:14
Next question: how reliable is the M5? bauhaus E39 M5 and E52 Z8 Discussion 3 3rd June 2004 19:23
speedometer error question HotWheels E39 M5 and E52 Z8 Discussion 7 6th December 2002 23:23
Age old question: Why did the chicken cross the road? DF7 Off Topic Forum 3 31st October 2002 02:56
Page generated in 0.14719 seconds with 11 queries
