Old 10th April 2006, 08:04   #1
Toddzilla
Toddzilla's Avatar
Garage: 1988 M5, Black
Procedure for replacing exhaust cam sprocket?
From what I've read, replacing the exhaust cam sprocket delivers a huge gain in sorely-needed torque on our 3.6L cars. I've searched and searched, but it doesn't seem that anybody has posted a procedure for doing this job.
Any tips? What other parts would I need aside from the sprocket?
Toddzilla is offline
Old 10th April 2006, 16:47   #2
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
Follow procedures for timing chain and gears.
unesential is offline
Old 23rd April 2006, 22:06   #3
Toddzilla
Toddzilla's Avatar
For what motor? The bentley manual has nothing for the S38.
1991 M5
2001 M3
Old 24th April 2006, 13:02   #4
shuggy47
shuggy47's Avatar
Garage: 93 E34 M5 3.8 Avus Blue
Chainging the sprocket is not hard just takes time.
Remove the cam cover upper chain 'guard' this will expose the sprockets.
to the front of the sprockets are two access panels. remove the one for the exhuast sprocket.At this point you will have to remove the tensioner.
once the tensioner has been removed unscrew the exhuast sprocket and position sensor and remove the sprocket and refit new one.
At no point allow the chain to fall down the gap, keep in tension.
Once the sprocket, chain and tensioner it refitted turn the engine by hand to ensure the timing is correct. at top dead centre the marks on the camshafts should line up with the brackets just behind the sprockets.
allignment pictures attached
shuggy47 is offline
Old 27th April 2006, 19:21   #5
Toddzilla
Toddzilla's Avatar
Thanks for the input. Wouldn't I need to remove the timing chain cover to get to the tensioner?
Thanks for the reply.
EDIT- Nevermind, I see now that I just need to unscrew the tensioner from the block.
1991 M5
2001 M3
Old 28th April 2006, 00:01   #6
shuggy47
shuggy47's Avatar
Not at all
You can gain access by removing the washer bottles.
That should give enough space to get a socket or spanner to loosen the tensioner.
From picture you can see the location.
Hope this helps
shuggy47 is offline
Old 28th April 2006, 02:45   #7
M540i LE
M540i LE's Avatar
Garage: 1995 M540i Limited Edition (Arctic Silver) & 1985 Hartge H23 (Alpine White)
I have read something about exhaust cam sprockets somewhere as well.
Maybe the tech guys on here can chime in with their thoughts on whether it is a worthwhile upgrade that could be done at the same time that I upgrade the tensioner?
Cheers
David B
Register of the 524 RHD 3.6 E34 M5's made - http://autos.groups.yahoo.com/group/E34M5RHD-register/
Register of the 70 540iLE's made - http://autos.groups.yahoo.com/group/BMW540iLE/
M540i LE is offline
Old 28th April 2006, 08:24   #8
Toddzilla
Toddzilla's Avatar
One more question. Should I just do the exhaust gear, or both? I haven't found a definitive answer.
1991 M5
2001 M3
Old 28th April 2006, 15:00   #9
Geach
Geach's Avatar
Garage: 1990 e34 M5 Sebring grey
Thats what I have been trying to work out?
Dan.
'90 M5- Sebring Grey
Geach is offline
Old 15th May 2006, 21:18   #10
Anton.P.
Anton.P.'s Avatar
Garage: M5 granitsilber 237
Send a message via ICQ to Anton.P.
Originally Posted by shuggy47
Not at all
Hope this helps
http://www.m5board.com/vbulletin/att...5&d=1146171419
In this pic i can see "tensioner"marked from you...
this detail may damage and leaked oil from here?
I see oil leak my front engine and don't understand what leaking in this location.
any idea...
M5 3.8 9.92 granitsilber 237
Anton.P. is offline
Weird change in exhaust note/sound?? jdv E39 M5 and E52 Z8 Discussion 7 19th December 2002 23:05
For you guys with Kellener's exhaust (83 mm size) I have a question for you, please.. FAST 5 E39 M5 and E52 Z8 Discussion 5 10th December 2002 14:56
400HP M3 (ECU, CAM, Exhaust) kevin034 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 8 13th September 2002 23:21
Appeal of an Exhaust Cam Sprocket samson E34 M5 Discussion 8 11th September 2002 16:00
Finally, a difinitive answer... Kelleners and Eisenmann are not the same exhaust!!! LSM E39 M5 and E52 Z8 Discussion 6 15th May 2002 06:23
Page generated in 0.14873 seconds with 12 queries
