Old 10th April 2006, 07:19   #1
redl1nerpm
redl1nerpm's Avatar
Garage: 91 M5 3.6
535i rear seat in M5??
My car has the 4 seat option. Could I simply get a rear seat from a regular E34 5 and put it in?
91 3.6 blk/blk
dinan s2, powerchip, eisenmann, 18 inch wheels
redl1nerpm is offline
Old 10th April 2006, 10:12   #2
illjah
Garage: 1995 M5 LE40/50 Orinico Green
yes.
illjah is offline
Old 10th April 2006, 13:22   #3
Sebring NL
Sebring NL's Avatar
check for the headrests though, I believe the back plate that separates the trunk from the cabin is a tad different when headrest are mounted. I believe the backrest is in fact held in place by the headrest IIRC from my shock replacement saga.
Maybe ALL 535i's come with headrests, but if you can choose, make sure you get those just in case.
The 525iX we had had an E32 interior in , which fitted straight away as well.
good luck
W
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
Old 10th April 2006, 13:39   #4
illjah
there are a few different types as well, which may have different mounting points (my 535i has foldable 33/66% rear seats that have a pivot point at front to lift seat bases forward to get seatback perfetly flat when folded, and is not held in my the two big clips as most other seats are).
but there should be no problem to fit pretty much any e34 interior - esp if Sebring NL says he's fitted in an e32 interior in a e34 as well!!
oh and btw my 535 has rear headrests, but they are self contained with the seat backs, due to it being a folding variety.
illjah is offline
Old 10th April 2006, 13:42   #5
Sebring NL
Sebring NL's Avatar
100% sure mate. Took it out myself. I even believe some sort of label or writing on the inside of the seat has E32 written on or something.
Old 10th April 2006, 15:45   #6
Stevie
Stevie's Avatar
Garage: e34 540i, Orientblau
And by 4 10mm nuts. 2 on the outer lower edges on the inner wheelarch and 2 on the hinge of the center armrest.....
One big advantage of the 5seat configuration is that in takes all of 2 seconds to REPLACE the battery. Try that on a 4 seater.....
Stevie is offline
Old 10th April 2006, 17:38   #7
illjah
my 4 seater is easy to get to the battery - just lift the seat cusion????? admitadly you may not be able to replace it or actually remove it (haven't had to do that on the m5 yet), but you can get to it easily enough.
illjah is offline
Old 10th April 2006, 20:17   #8
Sebring NL
Sebring NL's Avatar
that's right, they are plastic and most of E34's are missing at least one since people keep dropping them into the battery snakepit surrounding!
Simply slide out the headrests and the surrounding plastic and the backrest will come of easily.
Old 10th April 2006, 20:30   #9
redl1nerpm
redl1nerpm's Avatar
Garage: 91 M5 3.6
One big advantage of the 5seat configuration is that in takes all of 2 seconds to get to the battery. Try that on a 4 seater.....
sorry got you beat, it only takes 1 second on the 4 seater..
Sounds good, thanks guys.
91 3.6 blk/blk
Old 11th April 2006, 01:03   #10
WylM5
WylM5's Avatar
Garage: 91 E34M5 01E39M5
It may fit but there are differences. Most "regular" E34's that I see here US are all bench style in back so I guess you would have to remove your "bread bin" and perhaps the brackets below it as well as I don't recall seeing those on my Fathers 535. Also most E34's (especially earlier models) don't have the headrests and the seat back may require you to get rid of the center storage bin and do not have the lateral support of the M5 seat back.
1991 E34 M5
Dinan Stage III Suspension///Dinan Chip
Brembo Cross Drilled Rotors///HRE 340 Rims
Supersprint Exhaust///UUC Short Shifter
____________________________________
2001 E39 M5
Dinan Front and Rear Brace///Dinan Software///Dinan Differential///Dinan Rear Swaybar///BP Sway bar braket
///Tubi Exhaust
Brembo Front brake kit///UUC Short Shifter///UUC Clutch + Lightweight Flywheel///Rouge Engineering Tranny Mounts///UF Motorsports IATS
///Koni front + rear
WylM5 is offline
Getting Nostalgic, E39 M5 rumours from bmwm5.com back in '97! Gustav E60 M5 and E61 M5 Touring Discussion 12 18th February 2008 07:03
M5 / M6 Comparison Filthy Monkey E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 55 22nd November 2007 19:12
M5 vs. 996tt orangemarlin E39 M5 and E52 Z8 Discussion 21 28th July 2006 01:36
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 22:23
Page generated in 0.17595 seconds with 12 queries
