Old 9th April 2006, 16:05   #1
holtsaber
holtsaber's Avatar
Garage: E34 M5 3.6 in red
Gearbox problem
I suspect I have a nasty and probably expensive problem developing with my gearbox.
My beast is a 1992 3.6, but I'm not sure of the box variant.
The problem I have is when driving..... with enthusiasm.... every gear change from third to fourth results in a nasty 'crunch'. It always goes into gear, but it's not happy.
If you drive normally, the gearchange is fine.
I'd be very grateful for some advice as to what the likely component failure could be, and how extensive the repair process would be.
I live in Mid-Wales on the coast and don't know of any specialist anywhere close. I'm coming up on an inspection 2 being due for which my dealer who is 85 miles away has quoted me £750. If anybody knows of a decent engineer who can look after my M5 in this area, I'd be most grateful.
Adam
holtsaber is offline
Old 9th April 2006, 16:48   #2
farrell
farrell's Avatar
Sales Feedback: (4)
Hello
Sounds like sychroniser cones (synchromesh) giving up.
The box will run for a long time with this fault.
If it does not whine too much in the gears, then I would not worry.
If the box has done more than 150k miles, then you may want to consider rebuilding it as this is the only way you will address the synchromesh issue regardless.
budgeet for more than £1000 for a rebuild.
Buy a used box....risky
Buy a new transmission....expensive at over £2k.
There it is
Regards
Farrell
farrell is offline
Old 9th April 2006, 18:35   #3
Sebring NL
Sebring NL's Avatar
PM Geach..He's breaking an E34 M5
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
Old 9th April 2006, 22:15   #4
holtsaber
holtsaber's Avatar
Thanks for the guidance.
The box doesn't whine at all, it just crunchs on high speed changes into 4th, but it does still go into gear okay.
I was just worried that it may deteriorate. I think I'll leave it for a while and see if it gets any worse. The car has only done 93K and I only use it on weekends!
Any suggestions for where to get an Inspection 2 done, or should I accept BMWs £750 charge?
Adam
Old 9th April 2006, 22:25   #5
farrell
farrell's Avatar
Sales Feedback: (4)
Find a specialist by reputation.
Stealerships have neither the knowledge or expertise to work on these cars.
Doubtful if if they have ever had the expertise either.
Best of luck
Farrell
farrell is offline
Old 9th April 2006, 22:43   #6
Stevie
Stevie's Avatar
Garage: e34 540i, Orientblau
Do a fluid change. Dealers are known to ahem... "forget" to change it......
Stevie is offline
Old 9th April 2006, 22:58   #7
holtsaber
holtsaber's Avatar
Thanks Stevie.
I'm due an inspection 2 service, so I'll make sure it's done by someone who knows what they're doing and get the box oil changed too!
Old 10th April 2006, 03:34   #8
illjah
Garage: 1995 M5 LE40/50 Orinico Green
i had this on my old 5speed but going into 3rd from 2nd.
Try a change to redline atf might help a little, but as farrell says there aint a lot you can do without spending a reasonable amount.
illjah is offline
Old 10th April 2006, 10:41   #9
madm5
madm5's Avatar
Garage: BMW M5 3.8 white SOLD
This is exactly what was happening to mine- a crunch in to 4th only if you are driving hard. Mine was getting progressively worse, I expect every time you crunch it you are wearing it away a little more. I'm just hoping the box I picked up off ebay will be ok.
Adam
madm5 is offline
Old 10th April 2006, 20:49   #10
andy36
andy36's Avatar
Garage: M5 3.6 Sebring grey
Must be a pretty common trait with the Getrag 280/5 boxes as both my current M5 and the M6 I used to own had these symptoms. I covered over 20,000 miles in the M6 and didn't see any deterioration, however the M5 box would occasionaly stop you getting 4th altogether! The input shaft gear and laygear were damaged on this box (very noisy) so it has now been replaced anyway.
Incidentaly I have had the basic bearings and synchros rebuild carried out on a few gearboxes over the years and my local specialist charges between £250 and £400 excluding removal / installation depending on what it is. I can P.M their number if you like, they are in Preston, Lancs.
andy36 is offline
M6 gearbox problem after 2 months mat10874 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 11 25th September 2005 03:28
Gearbox oil plug leakage ilundber E34 M5 Discussion 5 22nd July 2005 15:42
Press Release no 3: The Seven-Speed SMG Gearbox Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 01:18
Power steering gearbox failed jay wilkins E34 M5 Discussion 0 29th July 2001 13:13
Page generated in 0.20449 seconds with 11 queries
