M-technic mirrors fitted today - Page 6 - BMW M5 Forum and M6 Forums
Like Tree3Likes
Old 12th April 2006, 15:41   #51
farrell
farrell's Avatar
Sales Feedback: (4)
In short, No
I looked at this aspect before putting the door panels back on.
There are 2 datum pegs & a big screw that locate & pull the mirror onto the door flitch.
To bring the mirror back to an ideal position, you need a 3mm thick packer.
If you do this , the mirror will not seal properly to the flitch & wind noise will occur.
Add to this the screw & cupped washer that ensure that the mirror is pulled flush & square up against the door flitch then being forced to secure at 7.5 degrees out of alignment, does not bode well for this method.
Farrell
farrell is offline   Reply With Quote
Old 12th April 2006, 16:14   #52
Brad Simpson
Brad Simpson's Avatar
Garage: Silber 91 M5 No. 5249
I don't like to shout but, YOU CANNOT USE E36 MIRRORS WITHOUT SERIOUS MODIFICATION!!!!!! I HAVE COUPE MIRRORS ON MINE AND EVEN WITH MODIFICATION THEY STILL DON'T FIT PROPERLY. THEY FUNCTION PERFECTLY (EVEN HEAT), BUT THE CONTOURS OF THE SUPPORTS ARE ADAPTED FOR THE M3. ALSO BE AWARE THAT THE E36 SEDAN MIRRORS ARE DIFFERENT STILL AND REQUIRE SERIOUS METAL GRINDING AND REDRILLING TO FIT. SAVE YOURSELF THE TROUBLE AND GET THE E34 M5 MIRRORS.
Brad Simpson is offline   Reply With Quote
Old 12th April 2006, 16:29   #53
Stevie
Stevie's Avatar
Garage: e34 540iT/6, Granitsilber
Hate to shout, but it seems you're the only one to even try fitting the wrong parts....... What does that tell you?
Stevie is offline   Reply With Quote
Old 12th April 2006, 17:29   #54
Geach
Geach's Avatar
Garage: 1990 e34 M5 Sebring grey
Now,now lads! You are gonna wake somebody up in a minute!
Dan.
'90 M5- Sebring Grey
Geach is offline   Reply With Quote
Old 12th April 2006, 17:32   #55
Stevie
Stevie's Avatar
Our local decendant of the famous corrupt Dukes of Hazzard Police Department chief, Darren P. Coltrane appears to be wide awake. Haven't seen much of his coffee-getter EnosE however.........
Old 12th April 2006, 17:37   #56
Brad Simpson
Stevie, you're a jackass! I was just trying to save someone else from making the same mistake I did because the the part numbers are the same. So, just . . . keep it to yourself!!!!
Old 12th April 2006, 17:40   #57
Geach
Geach's Avatar
Before you two start fighting,maybe you ought to read the whole thread from the beginning Brad?
Old 12th April 2006, 17:44   #58
Stevie
Stevie's Avatar
Well known fact. You're welcome!
The only partnumbers that are the same are the lenses and the housing, the feet (adapterplates) are definitely different as stated very clearly below. Farrell ordered the correct e34 parts, as many others have. Shout all you want, but don't make the guys doing it right look like pricks just because you ordered the wrong part. If you have anything usefull to add to this off-topic discussion feel free to PM me at jackass@m5board.com......
Old 12th April 2006, 17:47   #59
Simonal
Simonal's Avatar
Garage: Alpina B10 V8S Touring
(In a quiet and calm voice) Brad I think you have missed the first post by Farrell regarding M-Tecnic mirrors which was a while ago.
He has obtained the correct mounting plate for M-Technic (See got it right that time Karl) mirrors (These are often refered to incorrectly as Motorsport Mirrors and M3 mirrors) and fitted them as they were when fitted as optional equipment for the E34 M5, not sure of the date when they became optional but some time during the 3.8 era I think.
The problem possibly stems from the fact that the mirrors were only available for left Hand Drive E34s. This may mean that the angle for the passenger mirror (which is the drivers side in the UK) is incorrect and has caused the lack of vision.
We are all fully aware that you cannot use the E36 mirrors on an E34 but to my knowledge and this has been confirmed by others if you read this thread you can use the mirror lenses which is what Farrell has done. These were made for right hand drive and should allow the correct field of vision.
The problem could be caused by the mounting plate which as descibed above was only made in LHD format (provided you want the original equipment) and this is the problem we are trying to solve.
Simonal is offline   Reply With Quote
Old 12th April 2006, 17:50   #60
hertfordshire1
hertfordshire1's Avatar
Garage: BMW M5 e34
fight, fight, fight.......................
takes me back to everyone charging across the playground to see a couple of lads scrap it out!!!!
happy days!!
"If it breaks again.................. I give up."
hertfordshire1 is offline   Reply With Quote
Got creamed today MSB E60 M5 and E61 M5 Touring Discussion 24 11th October 2005 03:56
Additional Carbon Fibre now fitted to CSL!! JohnH E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 17 11th July 2004 00:38
OMG the World today only saw RED!!! Black M5 E39 M5 and E52 Z8 Discussion 11 8th March 2004 12:11
Funky mirrors on 02 M Funf E39 M5 and E52 Z8 Discussion 14 13th November 2001 01:29
