Lucky for me that I got the right mirrors I guess.
Apart from that, the mirrors wiring connector does NOT fit drectly into the door wiring plug connector of a rhd harness.
You need to remove the terminal pins from the connector on the end of the mirror harness.
You then have to power the mirrors & pin out the wiring order to ensure proper operation.
Both door cards need to be removed & all wiring for both mirrors needs to be accessable.
Some spare 15 amp bar fuses will be reqd to in case of a shortout.
Once the correct pinout has been achieved, Add a small pice of shrink sleeve to each of the connected terminals & joint them together.
Bobz.
I will get looking at the spacer after the planned trip to the Nurburgring.
I just cant be asked to strip the door card off again yet with so many other Jobs to do on the cars in the next 10 days.
Be assured that when one is made, you shall have one as well.
Cheers
Farrell
