Old 7th April 2006, 22:00   #1
whlightning
whlightning's Avatar
Garage: m5 e34 black
Electrical system problems
Hi,
The doors donīt unlock with the key in my car. A mechanic did try to hook battery in the bulb light sockets inside the trunk.
He didnīt check polarity first and now trunklight didnīt work.
What other damage in the electrical system may have occurred? Should I be worried?
Thank you
whlightning is offline
Old 9th April 2006, 23:28   #2
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
I'm taking it you are locked out of the car huh ?
Ok, go to the drivers side door,
insert key,
Raise the handle up as if to open the door.
At same time rotate key in lock in direction to open the door...
Continue to rotate key past the normal unlock point..
ie: about 45 degrees further than normal to unlock.
The button on the drivers door should raise.
Warning...the barrel may well be stiff as it doesnt ever go this far normally,
so be patient & carefull with your key.
This procedure will work, as it's in the handbook.
As for the trunk lamp, it's probably just a fuse.
Alan.
///M5 the only substitute for capacity is even greater capacity...
Alan Archer is offline
FS: K40 Integrated Front/Rear Radar system w/Laser Diffuser, just $625 shipped! RJM For Sale or Wanted 9 15th February 2006 15:14
Best Exhaust. (sound/vid) adam28 E39 M5 and E52 Z8 Discussion 64 15th September 2005 21:50
Key Fob Issue - you too? MAH E39 M5 and E52 Z8 Discussion 15 11th February 2005 21:35
Alpina B12 5.7 Coupe ShiftTronic CarlT ALPINABoard.com | BMW Alpina Discussion 3 15th March 2002 04:29
OT - Nissan's lane keeping system. The high tech march continues... blue max E39 M5 and E52 Z8 Discussion 8 9th December 2001 20:58
Page generated in 0.09539 seconds with 11 queries
