Hi,
When this thread is answered and the unit installed, I'll write it up, photograph it and delete this thread!
I pick up my E36 timing chain tensioner tomorrow.
As I understand it, the unit comes pretty much complete, it is better than the old one which came in lego form and required an Octopus to screw in correctly.
I cannot find an easy guide to fitting, with photos.
Queries:
Is the tensioner bolt on the side of the engine of the front? Any pics showing where?
I understand the washer bottle needs to come out. Is it just this bottle or the main coolant bottle?
Is it simply a case of unscrew the old one, pull it out, splash a bit of oil on the new one and bung it into the hole then do it up?
Does it have to go in "one way up" or anything?
If the chain is loose or worn, I hear theorectically that the chain can "slip" a notch. How? It hangs over the cam sprockets by gravity. I don't plan to take the cam cover off if avoidable, or is it the oil pump end that err... slips?
How on earth do I know whether this slip has happened or not?
If it did "jump a notch", am I looking at enough movement to hit pistons against valves on startup, or just a minor timing error resulting in less power/misfiring?
Would I notice it, is it dramatic enough that something is immediately knowable as wrong?
If it happens, how do I fix it? I'm poor with the MOT and Tax due this month, so cannot afford to tow to a garage and have the engine out!
I'm pretty sure the old one is leaking oil. Do I clean the area manually, or would judicious use of a non-steam pressure cleaner in that area alone do any harm before removing the old tensioner?
I hear it takes "half an hour" to swap the old complicated one for the new unit, as the new unit goes in very easily.
What spanners or sockets do I need? Might as well make sure I have all tools before crippling the car and having to walk to the shops!
Any tricky angles needing special/modified tools?
Any dupicate simultaneous items, like suddenly needing two sockets of 13mm being easier than a socket set and a spanner? lol!
I plan to camera the whole thing.
If it doesn't look a total nightmare I may even video it!
Accurate answers please! I plan to make a definitive tensioner change thread later, once and for all!
regards
Ivan
