Old 7th April 2006, 15:00   #1
Passmore
Garage: 1994 BMW M5 6 Speed
Swiss Eco Special
Gents,
I have a 1994 3.8 6 speeder. and love it.
However the Swiss 3.8 pushes out 327 bhp as opposed to 347bhp (DIN).
Apparently this is because the intake was fitted with a helmholtz resonator to tune the intake noise frequencies to meet strict Swiss pass-by noise regs. However, I have also heard that for the Swiss market smaller exhaust manifolds from the S38B36 engine were fitted (80mm vs. 90mm).
Anyone know as to if the above info is true - esp regarding manifold. Obviously I would prefer the extra 20bhp that have been taken from me by the over zealous Swiss.
Can I bin the helmholtz intake easily? i.e. will the DME be affected etc.?
any advice appreciated!
Passmore
Passmore is offline
Old 7th April 2006, 15:49   #2
illjah
Garage: 1995 M5 LE40/50 Orinico Green
I believe there is at least one other swiss member who have removed this, I'm sure a search will bring some stuff up (although I can't seem to find it at the mo!)
illjah is offline
Old 7th April 2006, 15:58   #3
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
I believe if you can obtain the standard air box you should have no difficulty. The DME should not be affected as it gets its info from the MAF which is the same. You will only be reduceing the restriction forward of the sensor allowing more airflow which the sesor is already capable of monitoring.
unesential is offline
Old 7th April 2006, 16:06   #4
unesential
There are 3.6 exhaust manifolds listed for several areas, Japan, Commonwealth, and Austria. IMHO there is not much difference in them as the Commonwealth people would be complaining if it robbed them of power. The RHD must require a different configuration of the plumbing than that afforded by the standard 3.8 manifold.
Is this so Farrel?
Old 7th April 2006, 16:52   #5
Sebring NL
Sebring NL's Avatar
LOL I searched for the thread I replied to at a swiss member for I recalled Illjah's story..:
Hubcentric rings
The swiss member was..Passmore!!
Obviously not much use in that!
I have a book on the S38b38 with a special section about the eco-stuff..Will look it up as soon as I can leave the office
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
Old 7th April 2006, 17:02   #6
Passmore
I have searched the board, can't find much info on it.....a little here:
Intake Horn
If I look at this pic from realoem:
Am I right in thinking I have items 11, 15, 16, 17, 18
and the standard setup is just item 10.
Or is the standard setup 10, 15, 16, 17, 18?
As to the exhaust setup, looks like the 3.6 manifolds were used in Switz. 'Commonwealth' is a strange term for BMW to use, the UK is head of the commonwealth - but they get the 3.8 manifolds!
Passmore
Passmore is offline
Old 7th April 2006, 18:03   #7
unesential
YEs you have all the added plumbing.
Old 7th April 2006, 18:08   #8
AlexA
AlexA's Avatar
Garage: 92 E34 M5 Touring Diamond Black
Passmore,
I think the Swiss 3.8 also looses some of its power due to it using the more restrictive ceramic catalysts from the 3.6, rather than the ones from the regular 3.8.
AlexA is offline
Old 7th April 2006, 18:25   #9
raymondw
raymondw's Avatar
[1] Yes,the Swiss version of the S38B38 only has 327hp. This due to the application of the S38B36 exhaust and S38B36 ceramic cats.
[2] All the B38's have the helmholz resonator. Principle of operation is that oscilations with a certain frequency can be attenuated by a cube with two holes. The resonance frequency can be tuned by the diameter of these holes. It doesn't affect flow-through as it isn't connected in series to the air-intake. You can find the helmoholz resonator underneath the air intake with which it is connected through a small pipe
[3] The Swiss version of the S38B36 has a bended intake nozzle that does affect flow through at high air-speeds. The ETK doesn't mention such a part for the S38B38 though.
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
Old 7th April 2006, 22:12   #10
Simonal
Simonal's Avatar
Garage: Alpina B10 V8s Touring
I think these changes were also applied to the Austrian version too.
Simonal is offline
Travel report E34 ///M5 meeting in the Alps 16-19 Sept 2005 raymondw E34 M5 Discussion 9 5th May 2006 10:33
Ferrari Enzo Special Edition Just_me GTBoard.com: General Sportscars 13 24th June 2005 03:54
A Special Rolls Royce: Centenary Phantom Millie Miglia GTBoard.com: General Sportscars 6 6th May 2004 23:32
Page generated in 0.16178 seconds with 12 queries
