Old 6th April 2006, 17:36   #1
illjah
Garage: 1995 M5 LE40/50 Orinico Green
Air Flow Meter
I the air flow meter item #1 in this diagram?
or the "mass air flow sensor" as described on there....
illjah is offline
Old 6th April 2006, 18:12   #2
Sebring NL
Sebring NL's Avatar
It's basically the whole thing inside/build in the metal round cilinder, you can see some sort of fragile device in there behind the mesh. Connects above with the slide-on connector. Regarded as MAF often in US speak
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
Old 6th April 2006, 18:13   #3
bay
bay's Avatar
Garage: BMW M5 3,8l 1993 Avus blau
Hi
Yes it is. do you have a problem with yours....
Bay
bay is offline
Old 6th April 2006, 18:50   #4
illjah
thanks, yes mine is knackered. As AndyE and me discovered, the protective screen (part #9 in pic above) appeared damaged and torn at the top, and I am getting a new one tomorrow along with the air flow meter (and o2 sensor). I was unclear on what was what, and whether this was indeed the MAF, as well as it being the item that my garage are replacing.
what could have possibly caused this damage? it looks like something has 'bown' thru piercing/tearing the screen
illjah is offline
Old 6th April 2006, 19:00   #5
farrell
farrell's Avatar
Sales Feedback: (4)
Very common failure this.
Ray W did an article for the E34M5.com/faqs on replacing the protective mesh screens either side of the MAF.
I made full use of the article back then..
Amazing when you look back at some of the articles being written by current members a few yrs ago.
Even then, Ray W & Gary Derian knew so much when I knew nothing..
Cheers Guys.
Farrell
farrell is offline
Old 6th April 2006, 19:08   #6
illjah
How does it happen tho farrell? Is it just wear & tear over time? or a blow-back etc?
And also could this failure of the screen cause the damage to my MAF, and therefore my subsequent engine problems??
I tried digging thru the e34 faq's but its hard when you're not sure exactly what you are looking for with no search facility!
Cheers again, as always!!
illjah is offline
Old 6th April 2006, 19:11   #7
illjah
So its all one unit:
also on this site: http://www.bmwe34.net/e34main/upgrade/Recipe.htm
it states upgrading the MAF as it is quite restrictive???? I don't understand, is the picture a non-OEM part? Or are they talking about upgrading the lesser e34 models??? (it mentions the m30 engine...)
illjah is offline
Old 6th April 2006, 23:48   #8
Sebring NL
Sebring NL's Avatar
I may be waaay off on this, but that doesn 't look like it at all!
I've had mine of so many times in the last weeks,only thing I can imagine is that plastic part being able to be detached from the metal housing. Would surprise me if it came out looking like that though.
My mesh was damaged as well, but I've simply left it out. Use it to drain the potatoes now
Old 7th April 2006, 01:04   #9
ilovemy_e34
Garage: 1991 M5 Brillant Red
Restrictive
I think restictive is in reference to the VANE air flow on the m30 and m20. It is that metal flap contraption.
Everytime you hit the gas the flap flies open and then falls back to guage the air flow. Where as the one in the picture, I believe, uses a heated wire to measure the airflow. (The cooling of the heated wire + math= airflow)lol
-Cory
Even the wisest of doctors are relying on scientific truths, the errors of which will be recognized within a few years time. – Marcel Proust
ilovemy_e34 is offline
Old 7th April 2006, 07:04   #10
M5-ready
Garage: Audi S6, Black
MAF's square plug (!!)
Hi folks! I searched the forum yesterday and found the thread about VW's MAF sensor alternative to our pricey item. I was intrigued by the part pictures, since my MAF (E34 M5 Touring) has a ROUND, SCREW-IN, 6-pin connector, instead of the square one shown in the diagram above (which is just like what VWs use, hence the direct use of VW's part). Does anyone have a clue about that? I need to replace the MAF asap - should I have the loom adapted to the square connector? TIA
M5-ready is offline
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 10:23
question about the functional aspect of the M5's spoiler masmole E60 M5 and E61 M5 Touring Discussion 15 25th October 2005 03:37
Dinan Air Flow Meter Question M5Kid E39 M5 and E52 Z8 Discussion 16 6th December 2004 03:26
GruppeM intake and Dinan Air Flow Meter Possible 540-aiite E39 M5 and E52 Z8 Discussion 5 2nd April 2004 05:32
mass air flow meter issues w/AA CAIS swynn E39 M5 and E52 Z8 Discussion 12 8th March 2004 19:46
Page generated in 0.16246 seconds with 11 queries
