Old 5th April 2006, 22:59   #1
E34M
Garage: 1992 E34 M5, Mauritius Blue
Replacing the clutch... Need some sudgestions..
Hey guys
My e34 M5 currently has a re-built Kevlar clutch from euro-drive.. (This is Dimitrys old M) (http://www.euro-drive.com/performance.htm) the clutch has been slipping, so either its junked or there is oil in it somehow. Anyway.. I wanted some suggestions as to a replacement. The car already has an 8lb JB flywheel, so that’s done..The car has been modified..bored over, new pistons etc.. Aprox 380hp... I wont be tracking the car, but I do drive it hard.. I am looking at either a Kevlar disk from euro-drive or a UUC ceramic or their metallic-ceramic version.. Any suggestions would be a big help as I am not quite sure what to do here..[/color]
Thanks!
Mike Klein
E34M is offline
Old 5th April 2006, 23:37   #2
farrell
farrell's Avatar
Sales Feedback: (4)
I suggest that you go back to the engine builder to see what he suggests.
How much torque is being generated over std.
Increasing the clamp load of the cover or changing the friction face material usually indicates greater torque/ power or track use where increased stress & shock loads are anticipated.
Is the transmission uprated with selected uprated syncronisers or modified gear sets.?
If not, its a std Getrag 280 which requires numerous regular oil changes & will expire if more load gets throught to it via the clutch.
Very often, the O/E manfacturer will strike a balance between function & durability.
Std clutches are designed to slip under persistant hard usage to save a very expensive part, ie the transmission.
If the disc is slipping under load & you find oil on investigation, that will be the rear mains crankshaft oil seal knocked off its seat.
Not unusual.
Farrell
farrell is offline
Old 6th April 2006, 08:02   #3
E34M
Tranny is stock..
E34M is offline
Old 7th April 2006, 00:57   #4
ilovemy_e34
Garage: 1991 M5 Brillant Red
I will just pass a little bit of advice that my dad told me... "It is better to lose a clutch than a transmission"
If you are not using it for the track then it is probably best to stick with an OEM clutch.
BTW you should do the gear selector seal, output shaft seal, and the rear crank seal... the parts should not cost more than 60 USD. But will save tons of time.
Another quick note: My dad also told me, after years and years of experience, that you should cut down the spring on the output shaft seal... It will totally prolong the life of the job
-Cory
Even the wisest of doctors are relying on scientific truths, the errors of which will be recognized within a few years time. – Marcel Proust
ilovemy_e34 is offline
Living with a Supercharged M5 from Discovery Automotive bbloch1114 Off Topic Forum 238 19th August 2005 18:04
New Sachs Power Clutch tripleD E39 M5 and E52 Z8 Discussion 13 12th April 2005 22:04
class action agiainst BMW? stanm5 E39 M5 and E52 Z8 Discussion 91 11th January 2005 23:28
Stage 3 (6-puck ceramic) clutch 1st impressions 1badm5 E39 M5 and E52 Z8 Discussion 11 2nd November 2004 22:00
Yet another clutch theory/technique thread greg E39 M5 and E52 Z8 Discussion 8 18th March 2004 18:55
Page generated in 0.12344 seconds with 11 queries
