BUMP
Been reading this thread, wondering if anyone has found a solution?
Recently, I had a leaky intensive washer pump (still working as I could hear the pump turn when I press the "S" button on the washer stalk), in an attempt to fix the rubber seal that fits at the bottom of the intensive solution tank I broke one of the nipples on the pump...just brittle I guess. Anyway I bought a new washer pump and rubber seal. When I installed everything, the "S" button wouldn't work anymore ????
In attempt to trouble shoot, if you unplug the intensive washer bottle pump but leave the others connected, then the intensive wash button "S" works again.
Also, I confirmed that the new washer pump works by connecting it to the main washer tank and running it from there, and the pump does energize and spin. So it's NOT the pump.
I checked the fuses #22 & #24 - OK, I then replaced the little grey relay #61361393415 with a new one - still no joy??
I connected a digital volt meter to the intensive washer pump connector, and noticed that as soon as I press the "S" button the volt meter jumps to 12V for a split second. This lead me to believe that voltage is reaching the connector but only on for a split second and not long enough to allow the washer pump to work.
HELP, any ideas...it just seems so strange that a simple pump replacement can cause this problem
