Old 5th April 2006, 00:42   #1
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Power Steering problem
My 3.6 has had SLS deleted and unfortunaltey one of the hoses at the rear started leaking.
So I blocked off some of the pipe work and got it a bit wrong. I blocked off the main feed from the power steering pump to the SLS and over pressurised the system and the feed pipe failed.
So now I have blanked off the pump itself where it fed the SLS.
problem I have is that itsnot working correctly now. its not bleeding itself and its making a whining noise all the time. Power steering fuild is being forced out of the reservoir.
So basically I think I've ruined the whole thing.
Can I fit a 535i Power steering pump? Will it bolt straight in?
Avus Blue 6 speed 3.8L E34 ///M5 Sedan
Evolve ECU Remap / Chip | Evolve Carbon Intake | Powerflex Black | Whiteline | Eibach Springs
2001 E39 530iA Sport
Cyrus is offline
Old 5th April 2006, 00:51   #2
Sebring NL
Sebring NL's Avatar
OK you know what im about to say so I won't.
Use an E34 pump ( I think 535 is the least risk, but my money is on most E34 pumps being the same) without the SLS feeds, have contemplated that myself.
I found that the pump needs to get rid of its pressure for SLS and thus can ;t be topped right off. Recircing is the solution. I 'd try that first and see where you are when the dust settles, mine ran some time with very low fluid and all is fine now
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
Old 5th April 2006, 01:12   #3
illjah
Garage: 1995 M5 LE40/50 Orinico Green
this has been my fear of all the old SLS pipework being left in place.
check out this article at bavarian Auto Sports:
http://www.bavauto.com/Assets/inst_p...34ElimKits.pdf
You'll need acrobat reader to view but has some good info on the SLS system.
(if you have troubles viewing [like wout!] then you can navigate thru from www.bavauto.com and click on tech info, then click on the "SLS elimination kit" link near the bottom of the page)
Ridding all that pipework is yet another job on the list of things to do in the long term...
illjah is offline
Old 5th April 2006, 15:48   #4
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
Yes , the standard pump will bolt right in. Hoses are different and need to be changed.
unesential is offline
Old 5th April 2006, 18:23   #5
joost
Registered User
Garage: e34 M5 touring six speed , Daytona violet metallic
Send a message via MSN to joost
you can also put the SLS feed line onto the return line of the pump.
works perfect and you don't have to buy another pump.
joost is offline
Old 5th April 2006, 18:40   #6
illjah
as detailed in the pdf i posted with diagrams.
illjah is offline
Old 5th April 2006, 21:25   #7
Cyrus
My problem is that i know nothing about this kind of pipework.
Sebring NL: You sell the pipework required for creating the loop? Does it come with all the right connections?
I serioulsy need to sort this out asap. If a 535i pump takes difference connections then its still not easy because I have to get a new connection on the old pipe.
Cyrus is offline
Old 6th April 2006, 02:02   #8
Sebring NL
Sebring NL's Avatar
I have those custom made using the connectors of the OEM ones.
Upgrade to 40% higher press capacity just to be sure.
have driven over 1000km with my setup ( high speed peaks) and no trouble.
Takes some effort to route the line well so it won 't give vibrations to the chassis, but this is easy candy for someone with your skills.
Old 6th April 2006, 12:20   #9
Cyrus
How quickly can you get a set sent over to the UK? I dont mind using express delivery services at a higher cost. I need my car back on the road.
Can you send one out tommorrow?
Can you post up some pics of where you've routed the pipes.
Cyrus is offline
Old 6th April 2006, 14:50   #10
Sebring NL
Sebring NL's Avatar
you have PM with my number, give us a call for info
Power Steering EDCIII fluid level Q plisken E34 M5 Discussion 4 20th December 2004 20:48
Power steering fluid Silverstreak E39 M5 and E52 Z8 Discussion 7 13th December 2004 18:27
Odd power steering failure mottati E39 M5 and E52 Z8 Discussion 7 8th November 2003 00:46
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
Page generated in 0.18998 seconds with 11 queries
