Old 4th April 2006, 00:50   #1
nixter
nixter's Avatar
Garage: '93 E34 M5 (Silver)
Front bumper removal
Hey guys, I have to fix a small leak in my washer fluid tank so I need to access it behind the bumper. What's the process for removing the bumper?
Thanks,
nix
1993 M5 Silver/Black
1980 911SC Widebody, Black/Black
nixter is offline
Old 4th April 2006, 01:14   #2
farrell
farrell's Avatar
Sales Feedback: (4)
Ok
Lay a cloth or sheet in front of the car.
extract the temp sender probe from the lower part of the bumper bar.
Remove the lh & rh front bumper rub strips.
They come off by pulling gently forward.
Once removed , you have a plastic retaining screw to turn 90 degrees on each side.
Then move to front of the vehicle & undo the 4 off bolts holding the bumper to crossmember.
Gently prise the bumper forward & detach washer lines & lay bumper on floor.
This job is best done with two of you as one can hold the bumper whilst the other detaches the washer lines that are essentially a double fit male/ female connection.
The O rings will need replacing in this connector block as they are generally the route cause of leaks unless a hig pressure line to the washers has perished but this usually only occurs on the hood washer jet lines.
Hope this helps
Farrell
farrell is offline
Old 4th April 2006, 01:21   #3
nixter
nixter's Avatar
Thanks for the info! The PO told me that he thinks the leak is from him not replacing some seal or gromet correctly back near the bottom of the washer fluid tank.
n
nixter is offline
Old 4th April 2006, 01:33   #4
Donati
Garage: 2 x '91 M5, Sebring Grey
Send a message via ICQ to Donati
Im sorry.. i must be missing something here..
In my car the washer-fluid tank is in the engine compartment, not hidden away behind the bumper, so i do not understand the question.. please explain
Mvh. Finn Donati
Donati is offline
Old 4th April 2006, 01:37   #5
nixter
nixter's Avatar
Yes, it's in the engine bay.
The PO told me that the source of the leak was at some connection near the bottom front of the tank which is accessible from behind the bumper.
nixter is offline
Old 4th April 2006, 01:38   #6
DaveW
Garage: Alpina B10 Bi-Turbo in Macau Blue
Intensive Wash - headlamps, foglamps - loads of pipes and plastic 'T' pieces...
Mine is leaking - not because of a physical leak but because the pump seems to go off all by itself, even when parked - very strange and I've no idea where to find the relay......
Dave.
DaveW is offline
Old 4th April 2006, 10:13   #7
farrell
farrell's Avatar
Sales Feedback: (4)
Yes
This washer system is triumph of function over practicality.
Many little cut lengths & "Tee" pieces.
Mine packed up about 3 yrs ago so I removed the bumper & stripped all the pipes that had fractured where they had been pushed together.
The connector that joins the bumper pipework to the washer tank mounted pipework is indeed easier to reach by taking the bumper off & its the main culprit for poor or no function.
The other way to service this part is to remove the washer tank & both pumps.
The connector can then be accessed by putting your hand down behind the bumper & wing.
On some occasions, the pumps giveup OR the wiring to them needs checking for breaks.
Remember that the pump mounted lowest in the tank is for the windscreen.
The headlamp intensive washer pump is mounted 50mm further up the tank & is pressed into the tank from the side nearest the front rh wing.
Aside frm this, the system is the most complex impractical headlamp cleaning system I have seen.
Farrell
farrell is offline
Old 4th April 2006, 13:49   #8
Geach
Geach's Avatar
Garage: 1990 e34 M5 Sebring grey
Dave.
Thats what mine used to do! Very strange.
Dan.
'90 M5- Sebring Grey
Geach is offline
have any of you M6 owners installed foglights on your front bumper? Choson1 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 5th January 2006 21:07
WTB E39 Front Bumper for 530i KrazyKidd For Sale or Wanted 0 25th May 2004 21:38
removing mesh insert from front bumper? ernie E39 M5 and E52 Z8 Discussion 7 6th August 2003 20:23
looking for the bottom front bumper piece for 91 m5 justin E34 M5 Discussion 0 23rd November 2001 20:58
Page generated in 0.14838 seconds with 11 queries
