Old 3rd April 2006, 22:19   #1
holtsaber
holtsaber's Avatar
Garage: E34 M5 3.6 in red
Nasty air pump!
My 1992 3.6 has the not uncommon problem of a grumbling air pump.
Over the last 6 months, it seems to have got much worse, and from cold the engine now has to be run for 5 minutes and re-started to make it go quiet!
Looking at the mechanics of the system, I see that the clutch that drives the pump is controlled by a relay which also feeds the vacuum pump.
If I remove this relay, or the fuse for this circuit, I am hoping that my noise will stop.
Does anybody know where either the relay or the fuse for this circuit is located?
If anyone has had a similar problem or found an alternative cure, I would love to hear from you........
Thanks,
Adam
holtsaber is offline
Old 3rd April 2006, 23:54   #2
graham4242
graham4242's Avatar
Garage: e60 B5s
Don't know if its the same as the 3.8 but in the cold the air the pump that comes on (to re-use the heat from the exhust) does sound very rough but a blip of the throttle makes it go away. Plus best not to let it idle just get in a go. Apologies if I've got the wronge end on the stick.
graham4242 is offline
Old 4th April 2006, 00:11   #3
holtsaber
holtsaber's Avatar
I think it is the same on the 3.8, but the purpose of the pump is to pump air into the exhaust manifold the help to reduce emissions and also reduce condensation in the cat?
As far as I'm aware, there would be no detrimental effect on the car if the pump was taken out of circuit, but I just don't know where the relay is located.......
Old 4th April 2006, 00:19   #4
Phlem5
Garage: 92 3.8, 5sp, Avus Blue(SOLD) & 95 LE 25/50
I think you can remove the drive belt as a quick solution, if I remember correctly ??.
Phil.
Phlem5 is offline
Old 4th April 2006, 00:24   #5
holtsaber
holtsaber's Avatar
That certainly would be one option if the belt isn't driving anything else, but in typical M5 fashion, it's just about impossible to get at!
Old 4th April 2006, 00:48   #6
joost
Registered User
Garage: e34 M5 touring six speed , Daytona violet metallic
Send a message via MSN to joost
the belt is easy to release, but it's also for the airco pump
joost is offline
Old 4th April 2006, 01:04   #7
holtsaber
holtsaber's Avatar
I don't want to lose the aircon with the 'warm weather' (haha) coming up, but I think I may have found an answer from an old post.
Apparantly the controlling relay is under the bonnet below a plastic cover next to the DME? unit. If I remove this relay then my beast will no longer resemble a tractor!
Old 4th April 2006, 01:42   #8
Donati
Garage: 2 x '91 M5, Sebring Grey
Send a message via ICQ to Donati
Completely correct..
Simply remove the relay under the dme plastic cover.. there are 3 relays in a row there, and its the one closest to the engine.. just pull it out, and the airpump will not engage at all.. plus: no side effects.
I did it on both my 3.6's.. hated the noise of that pump.. and dont really care if pullution is bit over regulations for the first 2min..
I have the electric diagrams somewhere, if you need it..
Mvh. Finn Donati
Donati is offline
Old 30th May 2006, 23:12   #9
VentoGT
VentoGT's Avatar
Garage: 2002 e46 M3 Carbon Black
Can someone please post a pic of this relay to pull? I don't want to pull the incorrect one...
VentoGT is offline
Old 31st May 2006, 14:41   #10
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
Should be closest to fender. Dont worry if you pull the wrong one the car wont start as the others control DME and Fuel pump.
unesential is offline
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 10:23
question about the functional aspect of the M5's spoiler masmole E60 M5 and E61 M5 Touring Discussion 15 25th October 2005 03:37
M-mobility air pump nozzle question... adegiulio E39 M5 and E52 Z8 Discussion 2 28th July 2003 18:28
How noisy is your air pump ? Husaborg E34 M5 Discussion 17 12th June 2003 19:41
Page generated in 0.14465 seconds with 12 queries
