Old 31st March 2006, 16:55   #1
IvanDias
IvanDias's Avatar
Alternator Regulator Replacement Technique Query!
Hi,
Have had Wane Ramseys alternator in the car a few weeks, but it looks like the regulator has failed. Battery voltage measured with the engine running is randomly anywhere from 13.8v to 17v, often fluctuating between 15.2v and 15.8v.
Windscreen wipers are as fast on "slow" as they should be on "fast" and "fast" is now manic! Fans vary with engine speed, engine "kicks" at high rpm and the ABS light comes on after a kick! Have stopped revving!
Have bought two regulators, but remember what a pain it was to remove the alternator. Will it rotate with only the bottom bolt attached, twisting without removing the lower bolt, around enough to fit the regulator? That bottom bolt is a real pita to remove so if I can avoid it, I will!!
Hope it doesn't rain Saturday!
Regards
Ivan
IvanDias is offline
Heel/Toe Shifting Technique How To BretCro E39 M5 and E52 Z8 Discussion 22 8th February 2006 16:46
19mm Rear Anti-Roll (Sway) Bar - Query IvanDias E34 M5 Discussion 13 1st March 2003 09:34
Anyone an expert on asymmetric Pirelli tyres - query!! IvanDias E34 M5 Discussion 6 2nd February 2003 19:55
Do car magazines need more articles on driving technique? bedllm Off Topic Forum 2 7th December 2002 06:18
bmwfilms- driving technique now showing... leebro1 E39 M5 and E52 Z8 Discussion 16 22nd June 2001 00:55
Page generated in 0.07856 seconds with 11 queries
