Old 31st March 2006, 08:58   #1
doc_76544
doc_76544's Avatar
Garage: 1991 BMW M5 all black
rear brake sticking
hey all,
i've noticed that after a short maybe 15-20KM drive my drivers side rear brake gets really hot, enough that you can feel the heat from it. there is also excessive brake dust on the wheel from this and it appears that my disk is getting quite worn down quite quickly. now i know i'm most likely going to have to replace the pads and rotors in the rear now as i would never only change just one on a set. but what could be the cause of this? perhaps a stuck piston? or perhaps the little pad slides are gummed up? would i have to replace the caliper as well or can it be un stuck easily?
thanks
shawn
doc_76544 is offline
Old 31st March 2006, 09:37   #2
corneredge
Garage: 1994 M5 3.8L Avus Blue
I've had this happen on older bimmers. Its most likely a stuck caliper. In the short term as a fix I've been able to "work" the piston free by removing the caliper and using clamps to work the piston back and forth. I bleed the brakes, and its ok for a short while. Depends on the exact problem.
Correct fix is to rebuild the caliper or get new.
-Russ
'94 M5
corneredge is offline
Old 31st March 2006, 09:56   #3
M540i LE
M540i LE's Avatar
Garage: 1995 M540i Limited Edition (Arctic Silver) & 1985 Hartge H23 (Alpine White)
I agree that it sounds like a sticky piston.
Best solution is to buy a rebuild kit (cheap), remove the calipers (relatively easy) and either rebuild them yourself or have someone elsedo it. In either case, much cheaper than a new caliper. Should get away for under 100 Euros in total.
Good luck
David B
Register of the 524 RHD 3.6 E34 M5's made - http://autos.groups.yahoo.com/group/E34M5RHD-register/
Register of the 70 540iLE's made - http://autos.groups.yahoo.com/group/BMW540iLE/
M540i LE is offline
Old 11th April 2006, 07:56   #4
doc_76544
doc_76544's Avatar
update: i parked my M5 for a while due to this problem and the lack of funds. when money came i ordered all neccesary parts two rear disks, set of pads and all the other little parts but not the caliper. i figured maybe i could inspect it and possibly free it up with lubrication and a little work. WRONG. after the M was parked for about a week and all the parts came in i went to grab it and take it to the local u-do-it place with lifts and all that. jumped in, warmed her up a bit and stuck it in first as usual and it took a little more pedal than usual to make her move. that caliper was frozen to the disk, it freed up but not without a loud crack noise. so since it was only like 200 meters to the lift place i drove it there, tossed it up on the lift and took everything apart i of course did the easy, unfrozen one first no problems, got to the other side and took it all apart, took the caliper off to realise the piston was completely corroded and unmovable. so i put the car back together less caliper and pushed it out of the lift area to park it as the lift place charges by the hour. and went back to the parts place to see if they had rebuild kits and or a already rebuilt one, no rebuild kit but they were able to order an already rebuilt caliper for exchange so i did it that way, i'm still waiting on that part to come in though hopefully it will be in tonight and i can finish my car and not have to ride my bicycle to work in the rain.
Shawn
Old 11th April 2006, 08:10   #5
M540i LE
M540i LE's Avatar
Doc
Bad luck. At least it was the more generic rear caliper (which is common with the 540i) and not a far more expensive - M5 only - front caliper.
Hope it all gets sorted soon.
Kind regards
Shawn
David B
M540i LE is offline
Rear brake pads mossy E39 M5 and E52 Z8 Discussion 1 15th January 2006 22:32
Official info and pictures (997 GT3 Cup) Andy-UK Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 5 14th September 2004 21:25
Looking for rear brake track pad options... Lscman E34 M5 Discussion 4 12th March 2004 11:04
B10 BiTurbo front brake pads and rear shock absorbers IGT ALPINABoard.com | BMW Alpina Discussion 6 6th June 2002 03:51
Adding LED rear turn signals and brake lights MAH E39 M5 and E52 Z8 Discussion 10 31st July 2001 17:21
Page generated in 0.13150 seconds with 11 queries
