Old 22nd December 2005, 14:46   #1
shuggy47
shuggy47's Avatar
Garage: 93 E34 M5 3.8 Avus Blue
measuring valve clearance and re-shimming
Alright Guys
Could anyone help me and talk me through how to measure the valve clearence and then and re-shim.
I know where the shims are and how to remove but not too sure about the specification clearances and therefor what size to replace the existing shims with once i find the current clearence.
Cheers
shuggy47 is offline
Old 22nd December 2005, 19:18   #2
bay
bay's Avatar
Garage: BMW M5 3,8l 1993 Avus blau
Re: measuring valve clearance and re-shimming
Hey
The valve clearances is 0,28-0,33mm Cold on the 3.8l and 0,30mm cold on the 3,6l. On the back on the shims it stands what size it is, so if you have a valve clearance there is 0,25mm and the shims is 3,40mm you install a new shims at 3,35mm and check clearance again. The shims size is 33mm in diameter.
Bay
bay is offline
Page generated in 0.07604 seconds with 10 queries
