Old 28th November 2005, 22:03   #1
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Z3 short shifter on 6 speed
Just incase anyone wants to know, the Z3 1.9 shifter works superbly in a 6 speed box.
I fitted one last night in garage. Was very cold and I couldnt feel much by the end of it but it was well worth it!
Cyrus is offline
Old 28th November 2005, 23:25   #2
BURTON
BURTON's Avatar
Garage: E34 M5 Black/Grey
Send a message via MSN to BURTON
Re: Z3 short shifter on 6 speed
I have had trouble fitting mine!
BURTON is offline
Old 29th November 2005, 10:57   #3
Rob Plummer
Garage: E34 M5
What parts do you need exactly? And how much!!??
Rob Plummer is offline
Old 29th November 2005, 14:54   #4
Cyrus
I just bought a 1.9 Z3 Shifter and the plastic ball holder thing.
Total cost about £40 inc VAT.
Took me 1.5 hours from when I drove the car into the garage and then out again with no issues.
What problems di you have?
Cyrus is offline
Old 29th November 2005, 14:55   #5
BURTON
BURTON's Avatar
I can't get the rubber boot off!
BURTON is offline
Old 29th November 2005, 16:33   #6
Cyrus
Just pull it off with some brute force.
If you think its going to tear then apply some grease above and below where it sits on the lever and all will be good.
They arent expensive if it does tear.
Have you been under the car to see if you can remove the circlip and push the lever rod out of the gear selector yet? Wasnt easy on mine, had to use various tools to get it to move and there isnt alot of access.
Cyrus is offline
Old 29th November 2005, 18:11   #7
ilundber
ilundber's Avatar
Garage: 1991 M5 Lagunengrunmetallic and 2001 M5 Le Mans Blue
Cyrus,
Do you know if it also would fit on the 6 speed box on the E39 m5?
/ilundber
ilundber is offline
Old 29th November 2005, 21:59   #8
Cyrus
NO idea for an e39 m5. You can try!
If the part number for the plastic gearstick ball holder is the same then it will fit but as to if the selector rod has the same fitting I dont know.
The probability is good to be honest, justy do some research on the parts and how they fit together and youll know.
Cyrus is offline
Old 30th November 2005, 16:02   #9
ilundber
ilundber's Avatar
Thank you. I'll have a look.
ilundber is offline
Old 13th February 2006, 23:01   #10
BURTON
BURTON's Avatar
had mine fitted today! Wow.. makes a huge different and I just want to keep driving the car!!!
Also its the first mod this year that I have done thats not a maintaince one!
BURTON is offline
Short Shifter Recommendations Please belly E39 M5 and E52 Z8 Discussion 16 31st October 2005 21:12
Short Shifter installed.... M5Racer E39 M5 and E52 Z8 Discussion 5 13th October 2005 20:08
New UUC clutch and Short Shifter cstucker1123 E39 M5 and E52 Z8 Discussion 1 11th April 2004 17:38
Short shifter RE vs UUC V-10 4 Me E39 M5 and E52 Z8 Discussion 4 13th March 2002 23:12
UUC short shifter installed--awesome! steveB E39 M5 and E52 Z8 Discussion 31 29th July 2001 06:48
Page generated in 0.16024 seconds with 11 queries
