Old 26th November 2005, 13:39   #1
Sebring NL
Sebring NL's Avatar
What about this synchronising injectors on 3.6?
I've heard today that its possible to synchronise the injectors on the S38B36. Mine is running good, just a little rough. Will have the valve clearances checked soon, but someone told me that it's also possible that non-synchroniswed injectors cause a slightly lumpy idle.
Anyone know the fact about this synchronising? Who in holland can do this for me?
Maybe it involves the little plastic white caps on the inlet manifold I reckon, that's the only part I can see qualifieing as a adjustment point.
thanks in advance,
A very happy M5 board user
Wout
Sebring NL is offline
Old 26th November 2005, 15:08   #2
bobz
bobz's Avatar
Garage: E34 M5 Black
Re: What about this synchronising injectors on 3.6?
thanks in advance,
Wout
I think you might be reffering to throttle bodies and not injectors, as the only way to check the operation of injectors is to take them out and have them sonicaly cleaned and then flow tested to make sure they are within spec.
BobZ
bobz is offline
Old 26th November 2005, 15:29   #3
Sebring NL
Sebring NL's Avatar
BobZ
I guess so, so what about that then?
Old 26th November 2005, 16:26   #4
raymondw
raymondw's Avatar
I cfan only recommend two things:
1: Have the injectors ultrasonically cleaned by a Bosch service station. Make sure, they also replace the O-rings and the tiny filters.
2: Check the basic throttle adjustment and if necessary, synchronize them.
3: Point two is useless unless the rest of the engine is not 100%. Therefore: a) verify and adjust the valve clearances first; b) replace all vacuum and underpressure hoses; c) Verify the fuel pressure.
The procedure for synchronizing the throttle bodies is complex, but if you are accurate and able to work precise, this is a DIY job. The exact procedure can be found on various internet sites (To complex to summarize).
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
Old 26th November 2005, 16:33   #5
Sebring NL
Sebring NL's Avatar
thank you raymond I knew you would chime in. I will have my injectors ultrasonically cleaned ( had that done on my E38 V8, nice difference), but you recommend to do the valve clearance first??
I understand that it's diffficult to state overhere, but where do I find most uf these vac hoses? Are they all around the airbox/filterhousing etc?
And is it possible that someone gives me a hand with these adjustments on the throttle, I've worked on a lot of cars but I'm very afraid to do something wrong on this car, last big job I did was removal of intake manifold on 730iV8 ( not easy!!). Would be very pleased if anyone would help me out, off course I will pay well. This is not a commercial forum I guess, but I hope that everybody understands my point since i've onl;y got the car for 4 months.
cheeers
Raymond thanks a million again,you can phone me too if you wish?
wout ( 0646333460)
Old 26th November 2005, 16:41   #6
raymondw
raymondw's Avatar
Yes.
I still am working on an FAQ article about this subject, but the basic idea is to remove the intake plenum, after which you see them. Please read This article from Jason Weaver first. It should answer all your question.
I refer to the M88/3 specification which include the procedure. For the S38, you can skip two parts, but please read the article first as I am certain that you will ask more questions.
Furthermore, I replied to a similar question on the Dutch BDC forum, for which I refer to This URL
raymondw is offline
Old 26th November 2005, 17:25   #7
Sebring NL
Sebring NL's Avatar
ok ray thanks.
So as I see correctly on your dutch article ( you are alpinaB10 or something overthere right?) its all a matter of adjusting the pushrods?? and the screws that will move the throttle valves?
I believe that it is necessairy to use a airflow meter just like Wber carbs??
am I missing something or is this just the beginning?
btw wont be able to look at this forum untill monday, hence my home PC is in trouble ( better that than my E34 still haha)
thank a lot raymond and others, what a big help in only one week! fantastic knowledge gathering overhere, really what I was loking for! you guys know your things...
cheers maters ( in english ) bedankt raymond
wout
Old 26th November 2005, 17:43   #8
raymondw
raymondw's Avatar
I believe that it is necessairy to use a airflow meter just like Wber carbs?? am I missing something or is this just the beginning?
This part is NOT required for part I, the basic mechanical adjustment which needs to be performed before proceeding with Part II.
Part II, the synchronization is based on the underpressure values in the intake system OR the CO values of each cylinders (only S38). Please note that the peak value is not a reliable reference. To determine an accurate value, use averaging techniques to determine the mean value per cylinder.
The goal for the adjustment is the calculated average of the mean values per cylinder. Measure the underpressure of each cylinder sequentially. Thus NOT in parallel as is custom to multiple Weber carbs. Yes, I know an FAQ article is in order and actually am working on it, but I am to short on time to complete it.
raymondw is offline
Old 27th November 2005, 17:24   #9
ilundber
ilundber's Avatar
Garage: 1991 M5 Lagunengrunmetallic and 2001 M5 Le Mans Blue
According to the manual, you can adjust the combustion by using these little "plastic topped things" . To get the right mixture you measure the exhaust fumes to make sure that you have the same CO value in all 6 cylinders.
The small tubes on the exhaust manifold that are pointing straight up are used for this. I will do that later on but it requires some test exquipment that BMW does not seem to have.
It all seems a bit tricky, so I will have to get someone to do it for me.
Cheers
ilundber is offline
Old 27th November 2005, 17:27   #10
Sebring NL
Sebring NL's Avatar
I love the fact that those germans think of EVERYTHING! will look into my pushrods 2morrow, wish me luck!
New 3.8 vs old 3.6 Initial report. Cyrus E34 M5 Discussion 8 25th October 2005 11:20
3.8 engine to replace 3.6 engine The Gorilla E34 M5 Discussion 14 26th August 2005 15:05
Should I bother going 3.8 from 3.6? Cyrus E34 M5 Discussion 12 17th March 2005 10:33
3.6 owner meets a 3.8 car... IvanDias E34 M5 Discussion 16 9th April 2002 10:57
B10 BiTurbo injectors question IGT ALPINABoard.com | BMW Alpina Discussion 7 20th February 2002 20:35
Page generated in 0.17984 seconds with 11 queries
