Originally Posted by doc_76544
farrell,
during a routine clutch replacement are both pt #1 and #6 usually changed? if so and one or the other are the fault then they will still be covered under warranty.
Shawn
Shawn
Pressure cover.
Driven plate.
Release bearing.
All the above would be routinely replaced as an assembly.
Pt6 would not form part of the clutch change generally.
They dont normally fail but they are a spring so they will fatigue over time.
The parts should however be inspected prior to reassembly by the technician.
Hope this helps
Farrell
