Old 18th November 2005, 10:31   #1
ilundber
ilundber's Avatar
Garage: 1991 M5 Lagunengrunmetallic and 2001 M5 Le Mans Blue
Climate control issue (inside the car )
Hi,
Since the winter now has arrived, I am having a small problem with the climat control in the car. The symptoms are:
- When pushing the front window defroster button, I do not get the full fan speed.
- I can't feel that the temperature is put to max when I push the defroster butten but I don't know if it should.
It is an"automatic climate control system" so I guess I will have to get a new control panel (or parts of it).
Does anybody know how to determin the problem by e.g. bypassing the reostat for the fan to establish what the max speed of can be?
Gratful for any advice.
Cheers
ilundber is offline
Old 18th November 2005, 17:30   #2
silverback mike
Garage: BMW E34 M5 BLUE/ TVR S3C GREY
Re: Climate control issue (inside the car )
Originally Posted by ilundber
Hi,
Cheers
Not too sure about the E34 control panel, but there is a very easy fix that I applied to my E36 328i, this had a similar problem which turned out to be a broken solder joint in the circuit board. BMW quoted a horrendous figure to fix, well, to replace the control unit.
I took it apart, found the joint, soldered it, it worked perfectly then.
It may be something as simple as that, I haven't worked on an E34 system, but may be worth checking out. Sorry I cant be much more of a help but just a thought.
silverback mike is offline
Old 21st November 2005, 14:20   #3
ilundber
ilundber's Avatar
Thank you very much. I''l look for "anything" that is broken and will see if I can fix it.
Cheers
ilundber is offline
Autocar: M5 beats Ferrari F430 Just_me E60 M5 and E61 M5 Touring Discussion 204 10th October 2007 17:24
The RUF experience, with a side order of M5 (very large and loads of pics :)) Adam E39 M5 and E52 Z8 Discussion 91 28th June 2007 03:41
Question: What's the worst sales tactics you've been through for new car sales? GradX GTBoard.com: General Sportscars 42 28th March 2003 04:37
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
Page generated in 0.15628 seconds with 11 queries
