Old 17th November 2005, 14:58   #1
BMW1191M5RI
Garage: BMW M5
Question for Mtec 2 Steering Wheel
I need help. I purchased a M-tec sterring-wheel off ebay from someone in Germany and he said that it fits E34, but when I went to change the steering-wheel the steering-wheel didn't fit. The hole on the steering wheel was smaller. What can I do to make it fit. Do I change the Steering column? And if so, which one do I use? A M3? I have a 1991 M5. I want to chnage the plain steering wheel into the Mtec Steering-wheel. The guy i purchased the wheel from in Germany says it did fit. Can someone please help help me, thanks in advance.
BMW1191M5RI is offline
Old 17th November 2005, 15:11   #2
farrell
farrell's Avatar
Sales Feedback: (4)
Re: Question for Mtec 2 Steering Wheel
If it is not a straight fit & more work is required. Take pics & measurements of the engagement splines & send to the seller.
If he can throw light on the adapter required then great.
Otherwise, throw it back at him with the threat of bad feedback & dispute resolution under the terms of "item not as described"
I would not change out parts of the steering to fit a wheel.
Farrell
farrell is offline
Old 17th November 2005, 15:18   #3
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
You may also encounter airbag problems which could fail safety inspection.
unesential is offline
Old 17th November 2005, 17:22   #4
illjah
Garage: 1995 M5 LE40/50 Orinico Green
no air bags in the mtech2 wheels - airbags weren't added til '94 i think.... i'm sure someone can correct me on that.
But if it doesn't fit, I'd say its not for an e34.
illjah is offline
Old 17th November 2005, 18:21   #5
Philn
Garage: e34 3.6
They did mtec 2s for e30's. These were slightly smaller, but as far as I know the spline is the same.
Phil
Philn is offline
Old 17th November 2005, 20:31   #6
ste
Garage: e34 M5 3.6 (Macau Blue)
Phil
The ETK shows 3 differnet M-tech II wheels.
2 are for e30 and e34. They only differ in size (370mm and 385mm).
The third looks identical but fits pre-airbag e36 cars and is not compatible with the e34. I guess you have one of those.
ste is offline
Old 17th November 2005, 21:27   #7
illjah
Originally Posted by ste
....The third looks identical but fits pre-airbag e36 cars and is not compatible with the e34. I guess you have one of those.
If it is indeed one of these, i may be interested in it for my missus' e36.
illjah is offline
Old 3rd April 2006, 18:15   #8
vespam5
Garage: 1993 M5 Black
Steering wheel question.
So E36 cars share the steering wheel fitment with airbag e34's?
Momo e36 steering wheel hub will fit my 93 airbag m5?
Anyone know?
vespam5 is offline
Old 3rd April 2006, 18:24   #9
Stevie
Stevie's Avatar
Garage: e34 540i, Orientblau
Anyone know?
There were 2 airbag fitments with both e36 and e34. Both old ones will swap and both new ones will swap. I don't know about airbagged-to-non-airbag.
Stevie is offline
Old 3rd April 2006, 18:28   #10
vespam5
Yes, from searching it seems that non airbag to non airbag fits and airbag to airbag fits.
vespam5 is offline
2000 to 2001 steering wheel upgrade question cosioboy E39 M5 and E52 Z8 Discussion 13 25th July 2005 18:29
steering wheel controls question ContractR E39 M5 and E52 Z8 Discussion 12 21st February 2005 18:13
Did any BMW come with a SMG Pedals + Heated steering wheel? Auraraptor E39 M5 and E52 Z8 Discussion 2 6th October 2004 05:52
Automatic steering wheel tilt krullshards E39 M5 and E52 Z8 Discussion 20 20th August 2002 17:44
steering wheel lock et1bill E34 M5 Discussion 1 17th August 2002 17:08
Page generated in 0.15076 seconds with 11 queries
