Old 14th November 2005, 19:00   #1
AGIL
AGIL's Avatar
Garage: 94' E34 M5 3.8 Daytona Violet
EDC Help!!
Fellow E34 M5 Enthusiasts,
I have a 94' 3.8 with 65,000 miles on it. I have investigated deleting the EDC altogether, and I am choosing not to regardless of the cost.
Here is the scenario;
EDC P and S lights work the standard green color illuminates when selected. There has never been a computer alert for the suspension before on the dash. The car has had the battery cable disconnected for other minor work so the resetting the ECU is thing does not seem to be relevant. When driving on the highway at high speeds the front end bounces up and down a lot. The rear seems fine in all accounts.
I have researched the cost of the shocks and even the ECU so I am aware of the costs. What I want to know is if the suspension is shot why are there not any message warnings? Also Could it be a bad ECU? And if I replace the front shocks do or should I replace the rears as well?
Any help, suggestions, comments would be greatly apprecited.
AGIL is offline
Old 14th November 2005, 20:20   #2
madm5
madm5's Avatar
Garage: BMW M5 3.8 white SOLD
Re: EDC Help!!
Is it set to S or P? Should be on S as that is a lot firmer assuming you have the switch. Mine is bouncy when set to P
madm5 is offline
Old 14th November 2005, 21:05   #3
farrell
farrell's Avatar
Sales Feedback: (4)
Re: EDC Help!!
If the EDC dampers are weeping, there will NOT be a warning.
Jack up the front end & look for signs of weeping out of the top the damper.
If you have obvious fresh hydraulic oil , then its history.
Replace dampers & top up reservoir with CHF11S.
I would add that you dont have to replace dampers as across axle pairs as with conventional dampers.
Single unit replacement is ok as pressure for each damper is controlled via solenoids energised by inputs from steering angle potentiometer, speed input from axle & horizontal / vertical accelerometers.
If no leaks then check rear self levelling pipes & also examine suspension springs for damage / fatigue.
Farrell
farrell is offline
Old 15th November 2005, 02:03   #4
yewcorner
yewcorner's Avatar
Garage: E60 M5 Interlagos Blue
Re: EDC Help!!
Hi All
Just to avoid confusion; the front EDC dampers are self contained units and have their self contained fluid resovoirs. The rears are fed via the same SLS resovoir which also supplies the power steering system.
Farrell
2005 E60 M5 Interlagos blue
yewcorner is offline
Old 17th November 2005, 01:27   #5
rjack
Garage: 92 m5 - 95 m5
Re: EDC Help!!
Exactly, only replace units that are leaking. I notice you are in Ft. laud. I have a shop there if you want to bring it round and have it checked.
Richard.
rjack is offline
Old 17th November 2005, 01:52   #6
AGIL
AGIL's Avatar
Re: EDC Help!!
Really! Small World. who is your shop, I know a lot of people in the car business here?
Richard.
AGIL is offline
EDC Dampers Rebuilt! Perfect! Pepsmeister E34 M5 Discussion 19 24th March 2008 00:32
EDC question MT JTN E60 M5 and E61 M5 Touring Discussion 2 8th November 2005 23:31
Impending EDC Failure ? FinalEditionE34M5 E34 M5 Discussion 17 19th January 2004 20:20
EDC problem rogerb E34 M5 Discussion 2 19th April 2003 13:50
Replacing EDC Suspension with Hartge Kit rcalvin E34 M5 Discussion 0 4th December 2002 22:47
Page generated in 0.13071 seconds with 11 queries
