Old 14th November 2005, 18:17   #1
BURTON
BURTON's Avatar
Garage: E34 M5 Black/Grey
Send a message via MSN to BURTON
Cats!
No not the ones you feed Katkins, but the ones on the M5.
Now does replacing these make a difference?! If you replace them what do you go for? What gains are to be had?!
BURTON is offline
Old 14th November 2005, 18:28   #2
illjah
Garage: 1995 M5 LE40/50 Orinico Green
Re: Cats!
Remove them! Kill the world!! Spit flames out of your exhaust, and go faster.
What more could you want!! I plan to do mine as mines a '91 so will still pass an MOT without them
illjah is offline
Old 14th November 2005, 18:41   #3
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Re: Cats!
You could put straight through pipes in and see what happens. You'd probably need a remap afterwards though.
Cyrus is offline
Old 14th November 2005, 18:42   #4
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
Re: Cats!
I jahve read somewhere that they should not be removed totally as there is not enough back pressure for normal driving. The number of cells can be reduced giving a lowered pressure and maintaining drivability with a slight bump in high rpm power.
unesential is offline
Old 14th November 2005, 18:53   #5
BURTON
BURTON's Avatar
Re: Cats!
Iam thinking of some 100 cells.. I want Torque but want to try and get abit more oomph
BURTON is offline
Old 14th November 2005, 19:18   #6
Phlem5
Garage: 92 3.8, 5sp, Avus Blue(SOLD) & 95 LE 25/50
Re: Cats!
I got two bypass / straight through pipes fitted as I need to get the cats welded. I am planning to put the cats back on ASAP as the noise with s/sprint cat back system is a bit loud, there is less engine breaking and any powergains are negligable, I did think as soon as they were fitted that 2k - 4k rpm pick up seemed better and maybe a tiny bit more 6k - 7k, could just be the placebo effect though. I don't know if a re-map is required as the O2 sensor is ahead of the cats. Jahangeer reckons his cat mods are the way to go but I think most will say just leave M be.
Phlem5 is offline
Old 16th November 2005, 03:45   #7
mblaster
mblaster's Avatar
Garage: 91 m5 black
Re: Cats!
OEM cats gone.
Replaced with 2 small high flow cats.
No remapping. The engine runs fine.
91 E34M5 3.6 Dinan Stage 3, Konis, Dinan chip and cam gears, Kelleners strut bar,
Header back custom exhaust w/ Eisenmann Race 83mm, Staggered Polished T-Stars,
Passenger canyon puke bag.
mblaster is offline
Old 16th November 2005, 09:11   #8
redl1nerpm
redl1nerpm's Avatar
Garage: 91 M5 3.6
Re: Cats!
with exhaust, youll hate the sound
91 3.6 blk/blk
dinan s2, powerchip, eisenmann, 18 inch wheels
redl1nerpm is offline
Old 16th November 2005, 11:46   #9
Jahangeer
Jahangeer's Avatar
Garage: .................
Re: Cats!
I just about passed my MOT, which surprised me as 66% of my Kats are out.
So I took out two out of three cells from EACH bank of cats on my 3.8 and left the 100cells in. As Phlem5 said you feel slightly more torquey higher up. Not sure about hp gains.
mblaster's is also a good way to go if you want to experiment with the kats.
I think I will get another 100cell kat placed in each bank next spring so I dont have to worry about the MOT emissions being borderline - and not passing.
Regards
J
Jahangeer is offline
Old 16th November 2005, 18:09   #10
BURTON
BURTON's Avatar
Re: Cats!
I think I will get replacement CATS!! Now who does them? G Power? Or is a normal exhuast place good enough?
BURTON is offline
UK - Upgraded exhaust ? Old Cats available ? [Tin????] stumbo E39 M5 and E52 Z8 Discussion 4 1st December 2004 18:48
anyone know the CPSI rating on the SS cats? CPSI= cell rating SC'dKellenersM5 E39 M5 and E52 Z8 Discussion 4 9th November 2004 18:44
IF CATS removed.....Or m5 rus E39 M5 and E52 Z8 Discussion 22 1st June 2004 08:45
Standard cats vs high flow cats ? madmax E39 M5 and E52 Z8 Discussion 0 15th March 2004 08:45
News from Supersprint...headers and racing cats available! TriflowM5+M3 E39 M5 and E52 Z8 Discussion 6 15th October 2003 22:58
Page generated in 0.14368 seconds with 11 queries
