Old 14th November 2005, 14:08   #1
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
ECU workings
The ECu takes signals from various sensors (crank, MAF, AIT, TPS, water temp etc) and then does its calucaltions and fuels accordingly.
Now my question is specific to the water temperature.
Does the ECU alter timing and fuelling given different water temperatures?
The reason I ask is because my car doesnt seem to come out of the blue are on the guage. This I thought may have been the sensor itself but using a barometer I saw max temperatures of around 45 degrees C at the radiotaro and pipes. My thermostat is obvioulsy stuck wide open.
but would this effect the timing and Fuelling?
Cyrus is offline
Old 14th November 2005, 17:55   #2
Phlem5
Garage: 92 3.8, 5sp, Avus Blue(SOLD) & 95 LE 25/50
Re: ECU workings
I think it might affect the fueling. My car seems a bit rich at the moment, a couple of mechanics I have spoken to mentioned water temp sensor as a possible cause.
Phil.
p.s. are you getting me a price for koni dampers we spoke about a while back ?
Phlem5 is offline
Old 14th November 2005, 18:48   #3
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
Re: ECU workings
You have 2 sensors 1 for ecu and the second for gauge. If your running cold the ecu will compensate.
unesential is offline
Old 14th November 2005, 19:32   #4
Cyrus
Re: ECU workings
This is then 100% my problem.
Wilbe fixed tommorrow with the arrival of new thermostat.
Cyrus is offline
Old 15th November 2005, 18:04   #5
Wane Ramsay
Wane Ramsay's Avatar
Garage: Estoril blue E39 M5 Individual 2001
Re: ECU workings
I have an ECU from my 3.8 m5 that your'e welcome to try,i think that you are fairly close to where i live.
Wane Ramsay is offline
Old 15th November 2005, 18:24   #6
Cyrus
Re: ECU workings
Please PM me your number.
Cyrus is offline
Help Please - advised to get a replacement ECU for EDC..... M5TouringFan E34 M5 Discussion 22 4th March 2005 15:32
Powerchips or Kelleners ECU? hsmith E39 M5 and E52 Z8 Discussion 4 17th February 2005 18:20
ECU, EML, DME control unit and chips etc... jack880 E34 M5 Discussion 2 1st October 2004 02:31
Euro vs American ECU????? clauswagner E39 M5 and E52 Z8 Discussion 8 23rd October 2002 19:01
I'm in a bit a dilemma...which ECU to use (400 or 510+) Apples E39 M5 and E52 Z8 Discussion 7 15th January 2002 19:08
Page generated in 0.15203 seconds with 11 queries
