In a recent post, Cyrus stated:
1) Remove perfectly good Airbox and cut it up and replace filter with biggest maxpower one you can fit under bonnet - Now reversed
2) Remove mesh from both side of MAF because it was thought to obstruct airflow - will find out if MAF is also damaged
3) Weichers strut brace- look ok so might leave it there
4) Red stuff ceramic pads - crap - need to reverse
5) AVO rear springs.....
need i say more. Replacing with eithr stock a set of H&R
6) Drilled front light surround to aid airflow........i just wont say anything
7) Hayward & Scott Spitfire aeroplane noise making exhaust - reversed and awaiting pickup.
This car has been truly saved!
At least he kept it very very clean!
So I figured, maybe we should start a thread about what the previous owner of our cars did, thats just not right.. Ill start
1) removed front half of airbox so just the filter straped on by a coat hanger is sucking in air....reversed with a big K&N cone (hey its much better than it was) until I get the proper airbox
2) hose from airbox to engine with large cracks causing the car to run very lean, can you say dangerous?....reversed with new tube.
3) chrome replica M3 wheels (bling bling?) chipped, incorrect offset, and tires down to the metal straps...reversed with some 18 inch beautifully fitted wheels similar to M parallels with bfg tires
4) chrome shift knob...reversed with oem knob
5) racing dynamics polished strut brace...reversed because I honestly couldnt tell a difference with it off, and it looks like something that belongs on a honda civic
6) cheap aftermarket sony cd deck with such poor wiring, you would think a child did it...reversed with proper wiring and a high quality alpine unit.
7) high flow cat, no resonator, and eisenmann race exhaust, my ears still hurt...reversed with added resonators and a muffler on the way
8) Cheap black racing seat in place of driver seat...reversed with proper stock seat
9) eye brows or eye lids...reversed by being removed.
10) german concepts licence plate frame...removed
11) Spare tire flat...in the process of being reversed
12) M badges in place of BMW roundel...reversed
Like cyrus, atleast my previous owner also kept a very clean car.
