Old 13th November 2005, 12:48   #1
bay
bay's Avatar
Garage: BMW M5 3,8l 1993 Avus blau
Flywheel
Hey
Am thinking of remove some weight from my flywheel, but has anyone try to do it, or is it stupid to do so?
Bayfficeffice" />
bay is offline
Old 13th November 2005, 15:25   #2
vadas1
vadas1's Avatar
Garage: 1994 m5 / diamond black
Re: Flywheel
Originally Posted by bay
Hey
Bayfficeffice" />
Doesn't sound a great idea to me as BMW would have put quite a lot of thought into it. However your countryman, Finn, might know more.
ralph (vadas1)
* If it ain't broke fix it till it is *
vadas1 is offline
Old 14th November 2005, 19:47   #3
AGIL
AGIL's Avatar
Garage: 94' E34 M5 3.8 Daytona Violet
Re: Flywheel
Hey
Bayfficeffice" />:p>:p>
I removed my stock flywheel when i replaced the clutch. I went with a stock clutch and a JB racing flywheel. Very happy with the feeling, the car runs better. When I shift the rpms stay up there and when i shut the car off you do not hear that rough noise.
JB racing is in Florida, and is a very reputable company.
AGIL is offline
Old 15th November 2005, 23:54   #4
DrSakke
DrSakke's Avatar
Re: Flywheel
If your car is a 3.8 as I remember, then the easiest way is to switch to a S38B36 flywheel as it is only half as heavy. This means that the clutchg has to be the b36 item also, rest of the parts are the same .
Sakke
DrSakke is offline
Old 16th November 2005, 00:31   #5
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Re: Flywheel
There are driveability issues with lighter fylwheels.
My E30 has one fitted and it makes it alot harder to drive smoothly around town. The revs also drop alot faster which can be annoying when your in Lazy mode driving style.
The m5 is already a difficult car to drive smoothly at low to mid speeds - this will make it worse.
Cyrus is offline
Old 16th November 2005, 02:12   #6
Gop-Dogg
Gop-Dogg's Avatar
Garage: Granite Silver `93 Euro M5
Re: Flywheel
I went with the OEM single mass flywheel from the 3.6L M5. Definitely nicer.
`93 Euro M5 (3.8L)
`06 M3 CS
Gop-Dogg is offline
Dinan Flywheel vs UUC alpineblue E39 M5 and E52 Z8 Discussion 7 28th March 2007 20:50
I need a clutch.Can I re-use the Flywheel ?? jim mc d E39 M5 and E52 Z8 Discussion 5 31st October 2005 04:17
LIGHTWEIGHT FLYWHEEL RINGTAXI E39 M5 and E52 Z8 Discussion 0 27th October 2005 20:37
Dinan Flywheel help please. Stevus E39 M5 and E52 Z8 Discussion 14 29th November 2003 06:26
TECH: Roundel got me in a tizzy--VAC's lightweight flywheel!! Teutonaddict E39 M5 and E52 Z8 Discussion 7 22nd September 2003 17:46
Page generated in 0.12354 seconds with 11 queries
