Old 10th November 2005, 16:18   #1
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
Oil pressure sensor?
Onboard is showing Oil pressure sensor. Manual says this is a priority 2 refer to dealer. I've checked my ETK and Wiring diagram nothing shows a sensor, just a pressure switch. Is there something someplace I am missing or is it the switch. I'll pick up the switch it's cheap enough but need to remove plenum to install PIA.
Thanks,
John
unesential is offline
Old 10th November 2005, 16:20   #2
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Re: Oil pressure sensor?
Mine has the same thing, oil pressure is infact ok, its just some wiring/electrical problem.
just make sure oil pressure is ok before driving.
fitted exhaust?
Cyrus is offline
Old 10th November 2005, 16:22   #3
Phlem5
Garage: 92 3.8, 5sp, Avus Blue(SOLD) & 95 LE 25/50
John, I changed mine (oil pissing out of the terminal) recently. You dont have to remove the plenum though, a decent 22mm ring spanner should do the trick iirc.
Phil.
Phlem5 is offline
Old 10th November 2005, 16:23   #4
unesential
fitted exhaust?
Yes exhaust is up and is very nice. It seems louder when putting around than when at speed. Now I have this new problem along with a new vibration I suspect is drive shaft.
Old 10th November 2005, 16:27   #5
unesential
Phil.
I cant seem to get my meat hooks in there to remove the connector. Maybe I'll get my son to try.
Old 10th November 2005, 16:40   #6
Cyrus
Makes impressive noise when foot flat to floor over 4000rpm. Get someonee to drive the car down the road and take a listen.
Cyrus is offline
Old 11th November 2005, 23:00   #7
unesential
Phil.
Yes indeed it did, 24mm. The problem was that the ETK drawing shows the temp sensor as the pressure switch although part number was right. All is better now.
Thanks,
John
Old 11th November 2005, 23:02   #8
unesential
I guess thats what #1 son means when says he likes the sound of it.
I'm getting low oil pressure warning Gerg E34 M5 Discussion 7 27th May 2004 07:20
Oil pressure warning BMHJ E34 M5 Discussion 3 12th April 2004 10:51
Oil pressure warning bibbya E34 M5 Discussion 6 14th February 2002 21:48
Page generated in 0.12465 seconds with 11 queries
