Old 9th November 2005, 16:54   #1
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Brake Pads
What brake pads are people using with their 345 floating disks?
Textar are the origional ones but does anyone else make a decent set of pads?
Mine has unfortunately fitted with EBC Red Stuff ones which are quite bad news.
Cyrus is offline
Old 9th November 2005, 17:50   #2
illjah
Garage: 1995 M5 LE40/50 Orinico Green
Re: Brake Pads
how many degredating after market mods did your 3.8 come with??? Did he leave anything alone?????
illjah is offline
Old 9th November 2005, 17:55   #3
farrell
farrell's Avatar
Sales Feedback: (4)
Re: Brake Pads
The loose nut behind the strg wheel was removed at point of sale.
The previous owner was the biggest pointless accessory that M5 ever had.
Farrell
farrell is offline
Old 9th November 2005, 18:08   #4
illjah
Re: Brake Pads
Farrell
and Sal said you knew of the car previously??? I could say things like "takes one to know one" but i'm not sure i'm ready for the barrage of taunts that would no doubt be persistantly flowing in my direction!!!!
illjah is offline
Old 9th November 2005, 18:14   #5
Rob Plummer
Garage: E34 M5
Re: Brake Pads
Stick with the OEM pads.
They were developed to stop a 1700kg car from 170mph +, AND they keep the refinement.
I usually sing the praises of Mintex, but having tried them, I'll be going back to OEM ones.
Original Equipment is cheaper too!!
Rob Plummer is offline
Old 9th November 2005, 18:17   #6
Cyrus
Re: Brake Pads
Ok, lets make a list.
1) Remove perfectly good Airbox and cut it up and replace filter with biggest maxpower one you can fit under bonnet - Now reversed
2) Remove mesh from both side of MAF because it was thought to obstruct airflow - will find out if MAF is also damaged
3) Weichers strut brace- look ok so might leave it there
4) Red stuff ceramic pads - crap - need to reverse
5) AVO rear springs..... need i say more. Replacing with eithr stock a set of H&R
6) Drilled front light surround to aid airflow........i just wont say anything
7) Hayward & Scott Spitfire aeroplane noise making exhaust - reversed and awaiting pickup.
This car has been truly saved!
At least he kept it very very clean!
Cyrus is offline
Old 9th November 2005, 18:19   #7
farrell
farrell's Avatar
Sales Feedback: (4)
Re: Brake Pads
Git
Farrell
farrell is offline
Old 10th November 2005, 23:31   #8
rjack
Garage: 92 m5 - 95 m5
Re: Brake Pads
He he ! I had the same thing when I bought mine. The noddy selling it was proud of the fact that he had thrown the air box away and replaced it with a USED K&N that looked like it had been driven over a few times. Included in his sales pitch was a cusom made bracket to hold it all together made out of a metal ruler and tie wraps!
And yes, the mesh in the MAF had been removed and any plastic obstructing air flow.
"Well let me shake your hand , we have a deal".
rjack is offline
Old 13th November 2005, 00:22   #9
ECM4
ECM4's Avatar
Garage: E34 M5 3.8 6sp Kashmir Biege
Re: Brake Pads
Rob,
You could be right with the Mintex arguement. They can be great but sometimes they can be harsh and noisy. Mine are getting better with use (or maybe I'm getting used to them) but I certainly wouldn't be concerned with the standard pads.
Craig
ECM4 is offline
Old 13th November 2005, 10:45   #10
farrell
farrell's Avatar
Sales Feedback: (4)
Re: Brake Pads
I agree
The std pads used in the 4 pot , floating brakes version are very good, if a little dusty to say the least.
When I had single pot brakes & the 315 dia brakes, I used pagid intermediate pads.
The std pads were not up to it & wilted under hard use but there was a progressive decline.
Farrell
farrell is offline
finally: better brake pads for Alpina B8! mill ALPINABoard.com | BMW Alpina Discussion 19 22nd May 2007 00:55
replacing brake pads...... ContractR E39 M5 and E52 Z8 Discussion 2 13th July 2004 01:34
Axxis brake pads Chris Finlayson E34 M5 Discussion 5 18th June 2004 06:32
Help with brake pads DrPaul E34 M5 Discussion 1 27th June 2003 10:49
Advice Requested re brake pads MariettaM5 Track and Racing Forum 3 18th February 2003 02:53
Page generated in 0.17935 seconds with 11 queries
