Been busy on the M5 over the last couple of days:-
Sunday moring i decided to try to rectify the lumpy running so off came the fan and i cleaned the crank sensor with the aid of a paintbrush and some white spirit - you could eat your dinner off it now!
Also i decided i wanted to check the balance of the throttle bodies as sometimes it felt like the lumpy running was imbalance between the cylinders - almost like it was dropping onto 4 - got the intake plenum off without too much hassle and after giving all the throttle's a good clean up i got the verniers out - i found that no.1&2 throttles were slightly advanced over 3&4 and 5&6 so i balanced these up.
Whilst the intake plenum was off i gave that a good scrub up too.....
Job no.2 was giving the front end a bit of a freshen up - the metal trim that runs along the bottom of the grille was heavilly pitted,stonechipped and in a few areas where the chips were down to the metal rust was evident - all this came off and gave me the opertunity to replace the offside main beam unit as mine was holed - id already found a good seconhand unit so killed two birds with one stone - headlamp is fitted and ive rubbed down, primed and painted the lower trim strip - just a final night in the garage to let the paint go off and itll be back together tomorrow.
Job no.3 was non functioning washer jets - had the same problem on my old E30 325i so removed the washer bottle to get access to the pipework - blew it all through with a high pressure bike pump and repeated the same of the actual washer jets themselves - jobs a good un
Just got to investigate the nearside front suspension clonk now.......
Pete.
97 Golf VR6 Supercharged - gone but not forgotten
93 Lagoon Green M5 3.8 Hartge
- gone but not forgotten....
Golf Gti Mk2 with a little bit of Audi 20V turbo under the bonnet
- gone and left a lasting impression in my mind!
Audi S2 Avant - not quite normal
