Front brakes and disks - BMW M5 Forum and M6 Forums
Old 26th October 2005, 17:24   #1
nebpor
Garage: Avus Blue E34 3.8 M5
Hi all, my 1993 3.8 has annoyingly juddery front brakes. Pads were Pagid fast road (this is Kurt Ramsden's old car), but I suspect either disks or pads are knackered as I tried to toast them to get them to stop juddering and it's not worked
What are my options for quality/economy replacements and what sort of price am I looking at?
thanks - sorry to ask the basic questions!
nebpor is offline   Reply With Quote
Old 26th October 2005, 18:18   #2
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Re: Front brakes and disks
are you sure its the discs?
Aure its not the bushes? Mince has the same problems and my bushes are worn.
Same thing happened to my forst 3.6 and my e34 Touring.
Get Powerflex ones when replacing. Will last longer than you have the car probably.
Cyrus is offline   Reply With Quote
Old 26th October 2005, 18:32   #3
nebpor
Pretty sure it's not the bushes - they were all checked when I got the initial shock bit of work done on the car ... plus I've melted enough brakes on my Honda to know what they feel like Car going for MOT imminently - I'll get him to check bushing as well then - thanks for the advice mate
Old 26th October 2005, 20:16   #4
Gop-Dogg
Gop-Dogg's Avatar
Garage: Space Grey `11 M3 ZCP
I recently replaced my warped front rotors with ZIMMERMANN X-drilled rotors. I think they were ~$90 each.
`11 M3 ZCP
`06 M3 CS
(Sold )
`93 Euro M5 (3.8L)
(Sold!! )
Gop-Dogg is online now   Reply With Quote
Old 27th October 2005, 11:30   #5
nebpor
I must admit I never go near X-drilled rotors - my track experience shows they tend to crack quite quickly with extreme use ... although I appreciate many peoples experience may be different!
Old 27th October 2005, 11:49   #6
Mmm-Five
Registered User
Depends on whether they were cast and then drilled (holes become the weak points), or cast with the holes in the template such as AP discs (no weak points and fine on track).
Slotted/grooved discs seem to be the way to go for fast road use, as they let the gases escape quite well and also keep the pad clean/smooth with a planing action as the pad scrapes past them.
Mmm-Five is offline   Reply With Quote
Old 27th October 2005, 12:54   #7
nebpor
I must admit from my own experiences (about 10 track days per year) the only reliable method has been blank disks ... but that's probably because I don't spend enough ... had bad experiences with slotted disks as well!
Anyway: this is just a quality, reliable road product I'm after, hence not wanting to spend too much
Old 27th October 2005, 18:32   #8
yewcorner
Garage: F10 M5 (2011) Silverstone/black
I had nighmare experiences with warping front discs. I tried a variety of EBC discs cross drilled, grooved etc.
I did get a combination of Black Diamond discs with EBC redstuff pads. The greenstuff pads just warped every disc.
My final setup which is superb are the later 345mm floating discs with the four pot callipers. Superb!
2011 F10 M5 Silverstone 11
yewcorner is offline   Reply With Quote
Old 28th October 2005, 01:25   #9
GoneAgain
GoneAgain's Avatar
Garage: 1988 Sebring Grey.....reborn
Couple of shops on German ebay selling Zimmermann discs, second one is cheaper, but I assume it's the same product. 65quid is cheap for 2 new discs!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=8008171795
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
GoneAgain is offline   Reply With Quote
Old 28th October 2005, 12:21   #10
nebpor
Fantastic - cheers for that
Detailed description on the M5 brakes from Continental Gustav E60 M5 and E61 M5 Touring Discussion 10 27th August 2008 12:45
FS: BMW 5 Series E34 M5 Front Brake Calipers, Disks and Pads vchachanidze Parts / Other For Sale or Wanted 0 6th July 2004 18:09
Brakes disks holes cast or drilled? johann E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 5 14th August 2003 04:26
Spare set of B8 Front Brakes BlackB8 ALPINABoard.com | BMW Alpina Discussion 3 13th July 2003 23:47
