23rd September 2005, 08:45
#30
Black '91 3.6
Re: Supercharging
Originally Posted by redl1nerpm
15000 for what? The s/c unit probably costs $1000, and the rest is just custom piping etc. I suppose if you have a shop do the entire install 15000 would be about right. And do you really think adding 130 hp to the stock already high strung engine is good? It might work, but for how long? My engine has about 125k miles and I wouldnt want to put that kind of stress on it unless I wanted to kill it within the next year or two.
Listed price for the kit is $9400 on AA's website. He purchased it himself and brought it to us to install. Installation time is somewhere between 15 and twenty hours. I agree there is not a lot of expensive parts but the kit comes with an intercooler, all the custom pipes, brackets to relocate parts, an electric fan, a new intake plenum with blow off valve, the supercharger which has it's own oil system with a reservoir and cooler, a new mass airflow sensor housing, a set of injectors, a set of spark plugs and several hoses and hardware. On top of all that someone is charging you for engineering and at the same time trying to make a profit. Since nobody wanted to do it for our cars I figured maybe I could get the hard parts made for someone who wanted to engineer it themselves and use my car as an example.
I believe the power was made at really low boost levels and as long as the mixture is kept correct it shouldn't hurt the motor until you exceed the physical limitations of the hard parts in the bottom end. I personally am more concerned about the rear suspension strength and will probably see what I can do about it. I can understand why you wouldn't want to modify it to that level I'm just willing to go through the hassles for the power. That and I'm one of the sickos that enjoys the work more than the results.
I heard that erebuni parts were terrible and I didn't buy them. Are they decent parts that use all the stock mountings or are they crap.
