Short Shifter - The BMW parts bin way. - BMW M5 Forum and M6 Forums
Old 13th September 2005, 13:33   #1
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
I done a short shift conversion on my E30. I used the Z3 2.8 Lever. The result.....brilliant!
At the same time I had the propshaft out on the M5 and it was up on axle stands. I decided to get under there and do a bit of measuring.
It turns out that the distance between the Pivot ball and selector rod is exactly the same as that of a standard E30.
The shape of the lever is very very similar to that of an E30.
The Pivot ball size is also exactly the same.
Therefore the Z3 1.9 or the 2.8 gear lever will go straight in.
The only thing you may have to do is slightly bend the selector rod upwards, you have to do this on an E30. Its only a small amount of bending and not enough to cause any weakening of the selector rod.
You can also use the Z4 Lever, its shorter in height and even shorter but will be quite Notchy.
There you go......some research done in the name of the E34 M5!
I doubt I shall be getting the UUC now as I cant see how it will be any better. Might just get the DSSR though.
Cyrus is offline   Reply With Quote
The Following User Says Thank You to Cyrus For This Useful Post:
vitomir (1st February 2012)
Old 13th September 2005, 14:27   #2
Rob Plummer
Garage: E34 M5
Re: Short Shifter - The BMW parts bin way.
Are you going to do it to yours then and let us all know how you get on?
Rob Plummer is offline   Reply With Quote
Old 13th September 2005, 14:29   #3
Cyrus
Yep.
Ordering it today. I will be ordering both the 1.9 and 2.8 levers to see what both are like.
Will give a review once they are in.
Sal
Old 13th September 2005, 14:52   #4
farrell
farrell's Avatar
Sales Feedback: (4)
Originally Posted by Cyrus
Yep.
Sal
Thats very interesting Cyrus.
I would be intrested in trying that mod if it does not cause gear clash.
Nice one
Farrell
farrell is offline   Reply With Quote
Old 13th September 2005, 14:55   #5
Cyrus
Whats gear clash?
Old 13th September 2005, 15:12   #6
farrell
farrell's Avatar
Sales Feedback: (4)
Whats gear clash?
Gear clash is where you dont fully engage the gears when the clutch is depressed. If the pivot ratio of the throw is not quite right, then you get a clash of gear sets as you select from one ratio to another.
It feels similar to a badly baulked gear change but the gear does engage.
Hard to explain but easy to feel.
Farrell
Old 13th September 2005, 15:14   #7
Cyrus
I think I will not bother with the 2.8 one then! I think I get this feeling on the E30 so better change that aswell.
The 1.9 lever is significatnly shorter than stock so it should do quite nicely and its very smooth aswell.
Old 17th September 2005, 13:26   #8
Cyrus
Hi Guys,
Just an update - I fitted the Z3 1.9 shifter last night. It sits perfectly in the middle, its around 1.5cm lower down now and the shift is alot shorter and much much nicer to use.
It took me a total of 1 hour from when I jacked the car up, most of the was used on actually getting the lever out as the old plastic ball holder was totally jammed and I had to break it out.
I also have a 2.8 one which I am going to try - It might be that little bit too short though.
As far as the Z3 1.9 is concerned its brilliant to use- very smooth, no gear clash.......fantastic cheap upgrade which cost me a total of £44 inclusing new clips wahser and the plastic holder.
Its like driving a new car!
That bit of research I hope will make alot of you very happy and will also save you absolutely loads of money.....£44!!!
Oh, and even the most basic mechanically minded person can do this. Nothing has to come out, its so easy to do.
I will post up the part numbers required when I next week when I bring the invoice to my office.
Old 19th September 2005, 13:43   #9
Cyrus
Anyone goin go try this??
Its brilliant!
Old 19th September 2005, 14:13   #10
farrell
farrell's Avatar
Sales Feedback: (4)
Its brilliant!
Hi Cyrus
Im interested in the conversion.
What are the pt nrs.
I have just set up a trade agreement with Lind BMW in Chelmsford.
The parts manager has extended this offer to ALL M5 Board forum members in what I would describe as the best discounts I have seen from a local dealer in yrs.
Thanks should be extended to Yewcorner for this.
Once Lind realised that Wiliam Jacks were prepared to offer such excellent service on pts, they have come up with the goods.
15% on average with some high cost items seeing 20% from what they are saying. They are willing to get involved in Group Buys...!
Cant say that I feel the same way from recent experience but there you go.
Due to Linds location nr Chelmsford, It wont encroach on William Jacks M5 Board customers within the Thames Valley area so that means most of the south east of England can now get some decent prices.
A bit off thread but though it worth mentioning.
Farrell
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 51 25th March 2005 17:14
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav Most Memorable Threads' 43 1st November 2004 19:16
BMW Alpina now launched in Kuwait, Quatar, Bahrain, Saudi Arabia and Oman! Gustav ALPINABoard.com | BMW Alpina Discussion 0 13th September 2004 23:31
Its Here! Real & OFFICIAL PICS of the new 5 Series car.............. FAST 5 E60 M5 and E61 M5 Touring Discussion 20 2nd April 2003 17:31
